AVM Fritz!Box and Plusnet TV
DougMa
Currently the AVM Fritz!Box doesn't work with Plusnet TV (and equivalents). Technically it can work, but doesn't include the required configuration nor can it be added by a user (without serious hacking).
The good news is that I'm working directly with an AVM engineer to add the support. I am hopeful it will be included in a future update. I'll post status updates here.
Doug
2 REPLIES 2
DougMa
Re: AVM Fritz!Box and Plusnet TV
Minor update:
- The Fritz!Box 7390 can support Plusnet TV only when using the built-in VDSL modem, not when using the Openreach modem.
- The Fritz!Box 7490 should support Plusnet TV in either configuration.
I'm continuing to test with AVM.
Doug
w23
Fixes: 4
That's good news @DoagMa, I'm still using your most helpful configuration 'hack' on my 7390 (which has survived Fritz!OS updates).
I was thinking about upgrading to a 7490 at some point but the difficulty in configuring the IPTV aspect was putting me off (I believe - could be wrong - that the hack is much more difficult with current firmware).
Call me 'w23'
