 time capsule
Jayappleaddict
 time capsule
Is the  time capsule router compatible w/ Youview+ from Plusnet.
Its the latest model, Is there maybe some settings that have to be changed. All help appreciated.
Cheers  Wink
4 REPLIES 4
ricke17
Re:  time capsule
I don't think it will work - read this: http://community.plus.net/forum/index.php/topic,140681.0.html
Rick.
Fibre Broadband 80/20, Netgear D7000
Jayappleaddict
Re:  time capsule
Thanks for the response. In airport utility i have IGMP option, but i don't know if that is going to do what i want. And i don't fully understand how this all works.
Cheers
ricke17
Re:  time capsule
Maybe someone else can explain better than me.
My set up used to be a Homehub 5 (wifi off) and time capsule for the wifi - I was able to use the HH5 for IPTV when I was with BT.
If the set up is the same in the link I provided, then you would need to have the openreach modem and the plusnet modem in situ and the time capsule connected too - but you would lose the gigabit ethernet connections that the time capsule has since the pn router is only 100 whereas the time capsule is a gig.
Hope that makes sense.
Good luck!
robbiecollie
Re:  time capsule
I also have a time capsule and no it will not work
