Fault troubleshooter maintenance - 4th Nov 22:00 - 5th Nov 05:00
HarryB
Fixes: 256
When's this work happening?
From 10pm 4th November until 5am 5th November.
What does it affect?
Broadband Fault Checker.
How long will it take?
Approximately seven hours.
What does the work involve?
Some essential maintenance is being carried out on the back-end systems used by our Broadband Fault Checker.
Am I likely to notice the work?
You won't be able to access our Broadband Fault Checker for the duration of the maintenance window and holding pages will be in place.
Is there anything else I need to know?
No.
Kind regards,
Customer Support
 Harry Beesley
