Fault troubleshooter maintenance - 22nd Oct 22:00 - 23rd Oct 06:00
Fixes: 18
When's this work happening?
From 10pm 22nd October until 6am 23rd October
What does it affect?
Broadband Fault Checker.
How long will it take?
Approximately nine hours.
What does the work involve?
Some essential maintenance is being carried out on the back-end systems used by our Broadband Fault Checker.
Am I likely to notice the work?
You won't be able to access our Broadband Fault Checker for the duration of the maintenance window and holding pages will be in place.
Is there anything else I need to know?
No.
Kind regards,
Customer Support
 Ben Babinski
