Fault troubleshooter maintenance - 20th July 17:30 - 21st July 10:00
HarryB
Fixes: 256
When's this work happening?
Tonight through to tomorrow morning.
What does it affect?
Access to our online faults troubleshooter.
How long will it take?
The troubleshooter will be unavailable for a period of time during the maintenance window.
What does the work involve?
Some maintenance is being carried out on the back-end systems our online faults troubleshooter depends on.
Am I likely to notice the work?
You won't be able to access our online faults troubleshooter for the duration of the maintenance window and holding pages will be in place.
Is there anything else I need to know?
No.
Kind regards
Customer Support
 Harry Beesley
