Fault troubleshooter maintenance - 15th Oct 22:00 - 16th Oct 07:00
Fixes: 171
When's this work happening?
From 10pm 15th October until 7am 16th October
What does it affect?
Broadband Fault Checker.
How long will it take?
Approximately nine hours.
What does the work involve?
Some essential maintenance is being carried out on the back-end systems used by our Broadband Fault Checker.
Am I likely to notice the work?
You won't be able to access our Broadband Fault Checker for the duration of the maintenance window and holding pages will be in place.
Is there anything else I need to know?
No.
Kind regards,
Customer Support
 Harry Beesley
