Fault Response Times
MatthewWheeler
Fixes: 479
Due to a number of issues including the recent storms, our suppliers are experiencing longer delays than normal to get phone & broadband faults sorted With these delays, it'll now take 5 working days to update on existing faults. We're really sorry for this inconvenience
Kind Regards
Customer Support
 Matthew Wheeler
3 REPLIES 3
MatthewWheeler
Fixes: 479
Re: Fault Response Times - NEW
Due to a number of issues including the recent storms our suppliers are still experiencing longer delays than normal to get phone & broadband faults sorted. This is currently at 5 working days. We're really sorry for this inconvenience
Kind Regards
Customer Support
 Matthew Wheeler
Chris
Legend
Fixes: 169
We've made progress on our response times to fault reports but these still may be 5 working days for a reply.
Although some faults are still taking longer than we’d like to respond to, we’re now replying to the majority in under 3 days.
We'll keep you updated on any changes to this.
Kind Regards,
Customer Support
Chris
Legend
Fixes: 169
We're continuing to work on bring the fault response times down, all faults should be responded to within 5 days.
Kind Regards,
Customer Support
