Errors viewing some TV channels (88476)
Fixes: 162
We're currently aware of a problem when trying to view certain channels on YouView TV from Plusnet. Attempting to view some channels may produce an error code similar to 'BTV-437'.
This is being investigated and we'll provide updates as they are available.
Apologies for any inconvenience caused.
Kind Regards,
Customer Support
 Chris Parr
 Plusnet Staff
1 REPLY
Fixes: 174
Re: Errors viewing some TV channels (88476)
We believe the problem causing the BTV-437 error code has now been resolved.
If you are still experiencing similar errors causing issues with viewing channels, please refer to our troubleshooting guides here: https://www.plus.net/help/tv/
Thank you for your patience with this matter. Apologies for any inconvenience this has caused.
Kind Regards,
Customer Support
 Harry Beesley
