Broadband Fault checker maintenance – 9th September 22:00 – 10th September 04:00
Fixes: 46
When's this work happening?
Saturday evening into early Sunday morning.
What does it affect?
Broadband Fault Checker.
How long will it take?
Approximately 30 hours.
What does the work involve?
Some essential maintenance is being carried out on the back-end systems used by our Broadband Fault Checker.
Am I likely to notice the work?
You won't be able to access our Broadband Fault Checker for the duration of the maintenance window and holding pages will be in place.
Is there anything else I need to know?
No.
Kind regards,
Customer Support
 Adam Walker
