Broadband Fault checker maintenance - 5th Feb 06:00 - 5th Feb 08:30
BenB
Fixes: 20
When's this work happening?
From 6am on the 5th of February until 8:30am on the 5th of February.
What does it affect?
Broadband Fault Checker.
How long will it take?
Approximately 2 and a half hours.
What does the work involve?
Some essential maintenance is being carried out on the back-end systems used by our Broadband Fault Checker.
Am I likely to notice the work?
You won't be able to access our Broadband Fault Checker for the duration of the maintenance window and holding pages will be in place.
Is there anything else I need to know?
No.
Kind regards,
Customer Support
