Broadband Fault checker maintenance – 29th July 00:01 - 17:00
Fixes: 46
When's this work happening?
Tomorrow, from Midnight onwards.
What does it affect?
Broadband Fault Checker.
How long will it take?
Approximately 17 hours.
What does the work involve?
Some essential maintenance is being carried out on the back-end systems used by our Broadband Fault Checker.
Am I likely to notice the work?
You won't be able to access our Broadband Fault Checker for the duration of the maintenance window and holding pages will be in place.
Is there anything else I need to know?
No.
Kind regards,
Customer Support
 Adam Walker
