Broadband Fault checker maintenance - 25th Feb 22:00 - 26th Feb 10:00
Fixes: 161
When's this work happening?
From 10pm on the 25th of February until 10am on the 26th of February.
What does it affect?
Broadband Fault Checker.
How long will it take?
Approximately 12 hours.
What does the work involve?
Some essential maintenance is being carried out on the back-end systems used by our Broadband Fault Checker.
Am I likely to notice the work?
You won't be able to access our Broadband Fault Checker for the duration of the maintenance window and holding pages will be in place.
Is there anything else I need to know?
No.
Kind regards,
Customer Support
 Matthew Wheeler
