Broadband Fault checker maintenance - 22:00 13th January to 04:00 14th January
Fixes: 36
When's this work happening?
What does it affect?
Access to the broadband faults troubleshooter
How long will it take?
Approximately 6 hours.
What does the work involve?
Some essential maintenance is being carried out on the back-end systems used by our Broadband Fault Checker.
Am I likely to notice the work?
You won't be able to access our Broadband Fault Checker for the duration of the maintenance window and holding pages will be in place.
Is there anything else I need to know?
No.
Kind regards,
Customer Support
 Adam Walker
