Broadband Fault checker maintenance - 14th Jan 22:00 - 15th Jan 04:00
Fixes: 173
When's this work happening?
From 10pm the 14th of January until 4am on the 15th of January.
What does it affect?
Broadband Fault Checker.
How long will it take?
Approximately six hours.
What does the work involve?
Some essential maintenance is being carried out on the back-end systems used by our Broadband Fault Checker.
Am I likely to notice the work?
You won't be able to access our Broadband Fault Checker for the duration of the maintenance window and holding pages will be in place.
Is there anything else I need to know?
No.
Kind regards,
Customer Support
 Harry Beesley
