Broadband Fault checker maintenance - 11th March 22:00 - 12th March 04:00
Fixes: 18
When's this work happening?
From 10pm on the 11th March until 4am on the 12th March
What does it affect?
Broadband Fault Checker.
How long will it take?
Approximately 6 hours.
What does the work involve?
Some essential maintenance is being carried out on the back-end systems used by our Broadband Fault Checker.
Am I likely to notice the work?
You won't be able to access our Broadband Fault Checker for the duration of the maintenance window and holding pages will be in place.
Is there anything else I need to know?
No.
Kind regards,
Customer Support
 Ben Babinski
