Broadband Fault checker maintenance – 10th June 22:00 - 11th June 06:00
MatthewWheeler
Fixes: 501
When's this work happening?
Tomorrow from 10pm until 6am on the 11th of June
What does it affect?
Broadband Fault Checker.
How long will it take?
Approximately 8 hours.
What does the work involve?
Our suppliers are carrying out maintenance on the back-end systems used by our Broadband Fault Checker.
Am I likely to notice the work?
You won't be able to access our Broadband Fault Checker for the duration of the maintenance window and holding pages will be in place.
Is there anything else I need to know?
No
Kind regards,
Customer Support
After the 3rd of November I will have a limited presence here as I have moved to a new role
 Matthew Wheeler
