new webmail
soundtrack
new webmail
There does not appear to be a means of the server to be set to remember the server name. On squirrel I could tick remember Force 9 but  Roundcube defaults to Plusnet each time that it opens. Shame too about the advert on the login page. Sad
This is my attempt to change colour/font size/ and Face!!! Tells you what asked for but does not do it.
sdfgh
Fixes: 46
Re: new webmail
Regarding the login server not being remembered. This is a known inconvenience that Plusnet said was not easy to solve. Using bookmarks it is possible to get directly to the appropriate login page (see quote below) but I don't think the setting is remembered on logout.
David
Quote from: Bob
Quote from: RPMozley
Will anything be done about remembering the server option?
We've toyed with a few ideas (like having different landing URL's) but one thing we don't want to do is fiddle with the vanilla code too much. We're conscious that this is probably the most commonly requested feature at the moment though so if we can implement it we will. In the meantime you might want to bookmark the following URL's:
Force9
FreeOnline
Metronet
David
Fixes: 58
Re: new webmail
At present on Webmail I have eight different logins which are remembered - with the new system non of these are remembered neither does Firefox have the option of remembering the password etc.
As far as I am concerned this is a deal breaker
drj
Re: new webmail
For info the RC webmail login DOES work with Norton Identity Safe - which fails on about 5% of websites (Photobucket being problematic for instance)
Moggy
Re: new webmail
I really like Norton Identity Safe...... BUT it won't work with Wndows 7 64bit.... DOH...
soundtrack
Re: new webmail
Ok will try various URLs to smooth entry to Webmail.
But what about the edit options? This same question has been repeated below with various enhancements that do not work.
But what about the edit options?  Angry
But what about the edit options? >
Fixes: 46
Re: new webmail
If one types some text, highlights it, then selects different format settings for the highlighted text these take effect for that text. Edits to the changed text retain that formatting. Outside the changed text, including immediately after it reverts to the previous format.
Though this behaviour is different from the way (eg) MS Word works, to me it seems normal for email editors. Were you expecting it to work MS Word style?
David
David
soundtrack
Re: new webmail
Yes, thanks David that works well.
Fixes: 46
Re: new webmail
Moderator's Note
Question concerning transferring Address Book from SquirrelMail to Roundcube split off into its own topic here for better visibility. Smiley
David
David
