Two little questions
Started using RC again as the login page is now holding my username/password though not the ISP.
Anyway, two little problems:
1. Has anything being done about the text wrapping problem? Mine is still a problem - having to scroll across to read even the shortest email.
2. When I delete mails there is a faint title left behind in the Inbox with the sender in bold type. When I opened up Windows Live Mail they downloaded even though I had deleted them. Has anyone else seen this?
Re: Two little questions
I have looked again to see if there are any settings that will improve the text wrapping problem. My website RC version is fine. Have even compared the two to see if there is anything different - nothing of note.
Has anyone been able to sort this out please?
Fixes: 46
I can confirm text doesn't wrap for me either, but I can't remember whether it has always been like that. It might be style settings that are missing.
What version of RC do you have installed?
David
David
I don't know the version - it just says Beta. Yes, it has always been like this - i commented on it way back when the trial began.
