Spell check performance
Fixes: 46
From what I recall spell checking originally worked, but it doesn't now.
When activated the "Checking" box displays, but the check takes a long time eventually returning with "no errors found" briefly displayed (even when lots of errors are present).
This problem was initially mentioned by artmo here.
David
David
Fixes: 70
Re: Spell Checking Not Working
Seems to be broken here too David (checked in FF3/IECool. I'll see if I can get somebody to take a look. Seems odd that it used to work.
Plusnet Products Team
Fixes: 70
Ok after a bit of digging we've determined that this functionality calls out to the Google spell checker (from the servers), and this hasn't been opened up.
This would suggest that it's never worked. Could you be confusing things with the build that Barry installed on one of his boxes?
Anyway, a change needs raising to open up the firewall to allow this call out and we've put this on our 'to do' list.
Fixes: 46
Quote from: Bob
I think you are right, it would be on Barry's own build that I saw spell checking working. Thinking back it might have been against a US-English dictionary too.
David
VileReynard
Seasoned Pro
Fixes: 9
In firefox, the builtin spell-checker works instantly as you type - but spell checking an extremely short email (using the spellcheck icon) takes a long time - 30+ secs.
Midnight_Caller
Re: Spell check performance
Quote from: spraxyt
Just done a test and the spell checking doesn't work, and it is very slow at Checking.
Yes, spell check doesn't work.  I raised this back in September and PN put it on their list of things to do.
