Server selection not remembered
Fixes: 46
The login server selector needs a "Remember Login Server" option like that provided for SquirrelMail (see attachment).
David
David
Re: Server selection not remembered
I use Firefox and it is not prompting to save password. Also noticed the absence of save server.
Any ideas why FF is behaving in this way? It's a bit of a pain having to type it in all the time.
Fixes: 70
Quote from: poppy
Are you talking about Squirrel or 'cube poppy? 'cube doesn't currently have a save password/server option.
Plusnet Products Team
Bob - you have been busy this afternoon answering all my questions - thank you.
Was referring to Cube - I still have to enter the username/password and server each time I use it but I assume that this is because we are still in beta and this will be sorted eventually. SM  is no problem - FF3 saves them and I just have to select Force9 when I first log on in the morning (I have it set to delete cookies when closing FF).
Midnight_Caller
Quote from: Bob
Why not?
RPMozley
Fixes: 4
Will anything be done about remembering the server option? Not everyone has a "plusnet" account and selecting it every time I want to log into a mailbox is rather time consuming.
That's RPM to you!!
Fixes: 70
Quote from: Midnight
Quote from: Bob
Why not?
Replying to an old post I know but take a look at the post here that also offers a temporary workaround.
Quote from: RPMozley
We've toyed with a few ideas (like having different landing URL's) but one thing we don't want to do is fiddle with the vanilla code too much. We're conscious that this is probably the most commonly requested feature at the moment though so if we can implement it we will. In the meantime you might want to bookmark the following URL's:
Force9
FreeOnline
Metronet
RPMozley
Fixes: 4
Ah, thanks for that Bob. Makes things a lot more easier. I certainly understand the reluctance to "mess about" with the code, who knows what consequences that could entail! Undecided
Edit: Oh, it doesn't seem to remember what was used before, after logging out. I suppose using the link only works one time then. Clicking the bookmark again only saves a maximum of one click (or none if link is in a folder).
That's RPM to you!!
Fixes: 21
This issue has come to the forefront since Tuesday, so it may be useful for users to be aware of Bob's little "hacks" (url's) in post #6 above.
Fixes: 9
Bob's links are to betawebmail, so if people are going to save them for long term use it would be best if they removed the beta!
jelv (a.k.a Spoon Whittler)
Mobile: iD mobile (£4/month)
Fixes: 70
There's a quick update here about the ability so save your username/password.
