[SOLVED] how do i create folders? and why won't dragging work?
i can't fathom how to make folders; right click doesn't do it.
sometimes a valid email appears in 'junk'.  i try dragging it to the inbox, but it won't have it.  i have to revert to squirrelmail to move it.
Fixes: 46
Re: how do i create folders? and why won't dragging work?
To create a new folder go into Personal Settings (along the top edge), select the Folders tab and you will find a Create new folder box at the bottom of the display.
For moving messages around, list the contents of the folder containing the message (Junk in the case cited). Click and drag the message to be moved from the list and drop it on the destination folder. This works for me, to and from Inbox or any other folder.
David
lovely.  thank you so much.
Midnight_Caller
Quote from: spraxyt
This does not work for me, I am using IE v6
[Edit]
Woops It does work.  Embarrassed
