RC not deleting emails properly (from Inbox)
As title says, emails are not being deleted into trash. The titles are greyed out with the exception of the Sender which remains in dark print.
If you open WM they will download even though they are supposed to be deleted.
Is anyone looking at this please?
Plusnet Staff
Plusnet Staff
Fixes: 159
Re: RC not deleting emails properly (from Inbox)
I've just tried and can't replicate it, if you go to Personal Settings which options are selected?
 Chris Parr
 Plusnet Staff
Thank you for that - checked in Settings as you suggested and removed ticks - now OK.
