Move messages to other folders
I have a folder that I created in SM called 'Saved' for messages that I am not wanting to immediately delete.
I used to click Move to....  but can't find this facility in RoundCube. The Saved folder appears in RC but I can't find the method of shifting messages into it. Can anybody help please?
Well, would you know it - you can drag and drop! Can't find any other way of doing it though.
Fixes: 5
Re: Move messages to other folders
Hi Puddy
Just drag the message into the folder.
Phil
Thank you for that Phil - as you can see by the above post, I just found it after posting - should have been less 'trigger happy'.
However, I suppose that another method might be useful for some.
