Aims and Timescales for the Trial
Fixes: 46
The aims of the trial are to review the suitability of RoundCube as an alternative Webmail solution to the current SquirrelMail offering. The key considerations of the trial are:
  • 1. To verify that the system operates trouble free for end users and Plusnet staff, is a suitable alternative to the existing solution and does not remove functionality that customers currently have access to.
  • 2. To prove the scalability of the solution, testing it under enough load to predict how the solution will scale up with the number of subscribers.
  • 3. To gauge what additional features customers would like from a Webmail solution and investigate the feasibility of developing such features.
Timescales
  • Phase 0: Closed Beta - Usergroup NDA & Pre-View Invitees: 08/09/2008
  • Phase 1: Closed Beta - Staff: 12/09/2008
  • Phase 2: Invitation Beta - All: TBC
  • Phase 3: Public Beta - All: TBC
  • Phase 4: Replace live platform - TBC
Success Criteria
The fundamental measure of success is customer feedback.
- Are people happy to use the solution?
- If it were offered to the wider customer base, would it be a popular option?
Technical success is being measured internally by Plusnet and those results won't be published here - This trial will focus on User Acceptance Testing of the solution.
Present Status
08/09/2008 - Phase 0 launched.
10/09/2008 - Phase 1 launched.
17/10/2008 - Further progression on hold; see Edit1 text below.
31/12/2008 - v0.2-stable downloaded to test server, but didn't make it to 'live' on the trial platform.
13/09/2011 - v0.5.4-stable release on the trial platform unsuccessful due to technical incompatibilities.
01/11/2011 - v0.6-stable released on the trial platform. New
This topic is work in progress, and will be updated as the trial progresses.
Edit1: Amended timescales as due to limited resource we cannot at the time of writing confirm when we will be in a position to move to Phase 2. Closed Beta applicants will continue to be considered for addition.
« 17/10/2008, 14:39 by Bob Pullen »
Edit2: Work towards releasing RoundCube to run alongside SquirrelMail resuming from 13/09/2011.
« ref post 09/09/2011, 13:20 by Bob Pullen »
David
