Quote from: Matt There's no difference between a modem disconnect and a router disconnect - if the connection is terminated, a disconnection is registered. If there's a number of disconnections within a certain time the exchange equipment picks this up as an intermittent drop and lowers the speed of the line to make it more stable and resistant to further disconnections.
Quote from: pierre_pierre during the initial 10 days, you should leave the router on to get you optimum speed.
Quote 3. The first 10 days
During the first 10 days of Max your phone line will be automatically measured to establish what speed it can support, and in particular at what speed the line will remain stable. The test will look to find out the lowest broadband speed you've received during the last 10 days. You'll see your sync speeds vary during this time, and you're likely to get disconnected from time-to-time. Whilst the testing is being carried out you should regularly make new connections to the Internet. It's a good idea to power off/on your modem or router when doing this, as this will force your equipment to reconnect.
Quote Whilst the testing is being carried out you should regularly make new connections to the Internet
