you don't help yourselves plusnet
- Feedback
- Plusnet Feedback
- Re: you don't help yourselves plusnet
27-01-2010 5:32 PM
28-01-2010 9:21 AM
28-01-2010 11:04 AM
28-01-2010 11:31 AM
28-01-2010 11:54 AM
I think the point of his question is that while routers may be left on all the time, PCs with modems are far more likely to be turned on and off!
28-01-2010 11:58 AM
Quote from: Matt There's no difference between a modem disconnect and a router disconnect - if the connection is terminated, a disconnection is registered. If there's a number of disconnections within a certain time the exchange equipment picks this up as an intermittent drop and lowers the speed of the line to make it more stable and resistant to further disconnections.
But this is exactly the point I'm trying (and obviously struggling) to make. From what you've told me in this thread, BT is taking a brute force and ignorance approach. Instead of using any sort of intelligence to determe whether there is actually a problem, they're blindly slowing connections for absolutely no valid reason whatsoever. How many people on this forum who are having slow connection problems ACTUALLY don't have a problem at all other than the one BT have created through crude mis-diagnosis.
28-01-2010 12:24 PM
For example, one disconnect a day (turning off your USB modem at night for example) wouldn't mean that your profile gets lowered. Bear in mind that it looks at things like errors on the line, and changes in sync speed as well (if you constantly connect at 8128 for example you can reset more often and not get impacted than if your connection speed fluctuates).
03-02-2010 10:44 PM
03-02-2010 11:19 PM
04-02-2010 8:21 AM
04-02-2010 10:33 PM
Quote from: pierre_pierre during the initial 10 days, you should leave the router on to get you optimum speed.
a quote from http://www.plus.net/support/broadband/speed_guide/dslmax_guide.shtml#Firstdays
Quote 3. The first 10 days
During the first 10 days of Max your phone line will be automatically measured to establish what speed it can support, and in particular at what speed the line will remain stable. The test will look to find out the lowest broadband speed you've received during the last 10 days. You'll see your sync speeds vary during this time, and you're likely to get disconnected from time-to-time. Whilst the testing is being carried out you should regularly make new connections to the Internet. It's a good idea to power off/on your modem or router when doing this, as this will force your equipment to reconnect.
04-02-2010 10:50 PM
05-02-2010 9:18 AM
I think that paragraph should be re-written. to give "precise" instructions regarding
Quote Whilst the testing is being carried out you should regularly make new connections to the Internet
to ensure that regularly and repeatedly are not confused.....
05-02-2010 10:27 AM
05-02-2010 10:36 AM
Anyone reading this thread from the beginning could be forgiven for thinking - to disconnect or not to disconnect - if so for how long - how often - that is the question.
If I do it MAY result in my connection being ultimately faster. But then again it MAY result in it being ultimately slower. It seems to depend on who's advising at any given time, who's interpreting what's going on with the line at any given time, whether they're having a good day or not. Whether there's a R in the month...
BTW - whatever ACTUALLY is the best thing to do - NO-ONE at PN advised me of this when I signed up. By the time I knew that this may or may not be a good or bad idea - my ten days were up. What a horlicks...
