worse connection and worse customer service
- Feedback
- Plusnet Feedback
- worse connection and worse customer service
31-01-2017 8:31 PM
i calling 20 times always waiting time more then 20 minutes my issue never been resolved my biggest mistake in life to join plus net i will never recommend anyone in my life for joining plus net .
i will take to trading standard not to delivering the product what promised.
Re: worse connection and worse customer service
31-01-2017 8:59 PM - edited 01-02-2017 7:08 AM
What exactly did they promise?
Seems to me that any third party outfit such as Plusnet that promises something they have little or no control over are being foolish to say the least. Up to 17mbs? Why not make it 100 and be done with it.
Many companies try to pull the same wool over our eyes of course with their 'up to' percentage off or on offers the majority of which are just figments of imagination, manipulation, and marketing.
PS. Mine has now slipped back down to 3mbs after three months of 5mbs. Cannot be bothered to complain any more after my six months of 1mbs and around twenty 'engineer' visits last year. Just total poop for many.
Truth is like a threshing machine; tender sensibilities must keep out of the way.
Herman Melville
01-02-2017 11:56 AM
What's the issue you're having? I can't see anything on your account right now that I can help with but if you want to let us know we'll see what we can do.
I can't see a reason for your speed dropping, it's still in sync at 6580 without any disconnections for 12 days.
01-02-2017 12:16 PM
01-02-2017 12:20 PM
Thanks for getting back to me.
Testing your line isn't showing any obvious issues, the router is connected to the cabinet at a good speed and line appears to be stable:
| Test Outcome | Pass | ||||
| Test Outcome Code | GTC_FTTC_SERVICE_0003 | ||||
| Description | No problem found, OAM test is not currently supported on this line. | ||||
| Main Fault Location | OK | ||||
| Sync Status | In Sync | ||||
| Downstream Speed | 40.0 Mbps | ||||
| Upstream Speed | 2.0 Mbps | ||||
| Appointment Required | N | ||||
| Fault Report Advised | N | ||||
| NTE Power Status | PowerOn | ||||
| Voice Line Test Result | Pass | ||||
| Bridge Tap | Not Detected | ||||
| Radio Frequency Ingress | Not Detected | ||||
| Repetitive Electrical Impulse Noise | Not Detected | ||||
| Cross Talk | Not Detected | ||||
| Estimated Line Length In Metres | 200.3 | ||||
| Upstream Rate Assessment | Very Good | ||||
| Downstream Rate Assessment | Very Good | ||||
| Interference Pattern | Not Detected | ||||
| Service Impact | No Impact Observed | ||||
| Home Wiring Problem | Not Detected | ||||
| Downstream Policing Discard Rate | 0.0 | ||||
| Customer Traffic Level | Upstream and Downstream Traffic Detected | ||||
| Profile Name | 0.128M-40M Downstream, Retransmission Low - 0.128M-2M Upstream, Error Protection Off | ||||
| Time Stamp | 2017-01-19T12:30:00 | ||||
Can you run a BT Speedtest for me, ensuring you do the further diagnostics test after the first one completes. This stores the results on the supplier system and allows us to use this to report the fault.
01-02-2017 12:25 PM - edited 01-02-2017 12:26 PM
Edit: Chris posted first.
01-02-2017 1:49 PM
Well it's running slow and often starts buffering when watching a movie, and that's the long and short of it Chris. Had the same issue before with all respect, being told all was fine when clearly it was not at my end.
Herman Melville
- Feedback
- Plusnet Feedback
