waiting for....
- Feedback
- Plusnet Feedback
- waiting for....
- « Previous
- 1
- 2
- Next »
Re: waiting for....
26-08-2010 8:35 AM
Re: waiting for....
26-08-2010 8:54 AM
I have been browsing this morning for about three hours, and only YouTube needed a refresh to get it started but was OK after that.
Your CNCzone site is loading in about eight seconds.
I have been looking as amazon.com (as opposed to amazon.co.uk) and speed there was fine.
eBay, bbc, plusnet, linksys.com, nectar, all seem fairly normal.
Re: waiting for....
05-09-2010 9:23 AM
Re: waiting for....
05-09-2010 10:43 AM
I also traced the route to www.cnczone.com to see if there were any problems or delays - but that came back OK too !.
C:\>pathping www.cnczone.com
Tracing route to www.cnczone.com [69.16.243.61]
over a maximum of 30 hops:
0 My_PC [192.168.xxx.xxx]
1 My_Gateway [192.168.xxx.xxx]
2 lo0-homesurf.pcl-ag04.plus.net [195.166.128.135]
3 gi1-10-606.pcl-gw01.plus.net [84.92.0.236]
4 te2-1.pcl-gw02.plus.net [212.159.1.114]
5 195.50.122.129
6 ae-34-52.ebr2.London1.Level3.net [4.69.139.97]
7 ae-41-41.ebr1.NewYork1.Level3.net [4.69.137.66]
8 ae-4-4.ebr1.NewYork2.Level3.net [4.69.141.18]
9 ae-1-100.ebr2.NewYork2.Level3.net [4.69.135.254]
10 ae-2-2.ebr1.Chicago1.Level3.net [4.69.132.65]
11 ae-6-6.ebr1.Chicago2.Level3.net [4.69.140.190]
12 ae-1-51.edge2.Chicago2.Level3.net [4.69.138.131]
13 GLOBAL-INTE.edge2.Chicago2.Level3.net [4.59.29.78]
14 lw-core4-te91.rtr.liquidweb.com [209.59.157.206]
15 lw-dc2-core3-ge2-15.rtr.liquidweb.com [209.59.157.104]
16 lw-dc2-sec1-dist1-po1.rtr.liquidweb.com [209.59.157.216]
17 host2.cnczone.com [69.16.243.61]
Computing statistics for 425 seconds...
Source to Here This Node/Link
Hop RTT Lost/Sent = Pct Lost/Sent = Pct Address
1 2ms 0/ 100 = 0% 0/ 100 = 0% My_Gateway [192.168.xxx.xxx]
2 15ms 0/ 100 = 0% 0/ 100 = 0% lo0-homesurf.pcl-ag04.plus.net [195.166.128.135]
3 23ms 0/ 100 = 0% 0/ 100 = 0% gi1-10-606.pcl-gw01.plus.net [84.92.0.236]
4 27ms 0/ 100 = 0% 0/ 100 = 0% te2-1.pcl-gw02.plus.net [212.159.1.114]
5 16ms 0/ 100 = 0% 0/ 100 = 0% 195.50.122.129
6 14ms 0/ 100 = 0% 0/ 100 = 0% ae-34-52.ebr2.London1.Level3.net [4.69.139.97]
7 83ms 0/ 100 = 0% 0/ 100 = 0% ae-41-41.ebr1.NewYork1.Level3.net [4.69.137.66]
8 83ms 0/ 100 = 0% 0/ 100 = 0% ae-4-4.ebr1.NewYork2.Level3.net [4.69.141.18]
9 83ms 0/ 100 = 0% 0/ 100 = 0% ae-1-100.ebr2.NewYork2.Level3.net [4.69.135.254]
10 109ms 0/ 100 = 0% 0/ 100 = 0% ae-2-2.ebr1.Chicago1.Level3.net [4.69.132.65]
11 105ms 0/ 100 = 0% 0/ 100 = 0% ae-6-6.ebr1.Chicago2.Level3.net [4.69.140.190]
12 106ms 0/ 100 = 0% 0/ 100 = 0% ae-1-51.edge2.Chicago2.Level3.net [4.69.138.131]
13 112ms 0/ 100 = 0% 0/ 100 = 0% GLOBAL-INTE.edge2.Chicago2.Level3.net [4.59.29.78]
14 118ms 0/ 100 = 0% 0/ 100 = 0% lw-core4-te91.rtr.liquidweb.com [209.59.157.206]
15 111ms 0/ 100 = 0% 0/ 100 = 0% lw-dc2-core3-ge2-15.rtr.liquidweb.com [209.59.157.104]
16 114ms 0/ 100 = 0% 0/ 100 = 0% lw-dc2-sec1-dist1-po1.rtr.liquidweb.com [209.59.157.216]
17 110ms 0/ 100 = 0% 0/ 100 = 0% host2.cnczone.com [69.16.243.61]
Trace complete.
Re: waiting for....
06-09-2010 5:02 PM
Re: waiting for....
07-09-2010 3:22 PM
Next time, can you post a tracert / pathping pre- and post- reboot to ensure you're on a different gateway, and to see if any difference is evident?
Re: waiting for....
08-09-2010 6:07 PM
forum.allaboutcircuits.com
www.machsupport.com/forum
www.cnczone.com/forums
and post the results - just the first bit - you could cntrl C out of the "Computing statistics" bit.
The sites are all safe - the first is an electronics forum, the second a computer controled machinary forum and the third the same sort of thing which you've done anyway. Anyway - just if you fancy.
Re: waiting for....
08-09-2010 6:26 PM
Tracing route to allaboutcircuits.com [208.101.14.162]
2 lo0.homesurf.thn-ag2.plus.net [195.166.128.94]
3 unknown.plus.net [84.92.4.176]
4 te2-3.thn-gw2.plus.net [212.159.1.58]
5 vl23.pte-gw2.plus.net [212.159.4.28]
6 cr1-linx-peer.lon005.internap.net [195.66.224.44]
7 cr2-cr1.lon005.internap.net [77.242.206.130]
8 lon005-wdc005-1069-cr1.wdc005.pnap.internap.net [66.79.147.37]
9 dal005-wdc005-1161-cr1.dal005.pnap.internap.net [66.79.147.217]
10 dal005-dalext1-846-core3.ext1.dal.internap.net [66.79.145.98]
11 border3.tge4-1-bbnet2.ext1.dal.pnap.net [216.52.191.83]
12 te1-2.cer01.sr01.dal01.networklayer.com [216.52.189.30]
13 po2.fcr01.sr01.dal01.networklayer.com [66.228.118.158]
14 supcast.com [208.101.14.162]
Computing statistics for 350 seconds...
^C
C:\>pathping www.machsupport.com
Tracing route to machsupport.com [69.64.89.93]
4 vl22.pte-gw1.plus.net [212.159.4.11]
5 te2-4.pte-gw2.plus.net [212.159.1.102]
6 1-2.r1.lo.hwng.net [195.66.224.227]
7 4-1.r1.ny.hwng.net [69.16.190.209]
8 3-1.r1.ch.hwng.net [69.16.191.41]
9 1-1.r1.la.hwng.net [69.16.191.33]
10 2-1.r2.ph.hwng.net [69.16.191.38]
11 ve1012.ar2.ph1.hwng.net [69.16.190.166]
12 network-69-16-135-206.phx1.puregig.net [69.16.135.206]
13 gi1-45.dr1.dg1.phoenix.codero.com [69.64.66.26]
14 mail.machsupport.com [69.64.89.93]
^C
5 te-3-4.car5.London1.Level3.net [217.163.45.181]
7 ae-44-44.ebr1.NewYork1.Level3.net [4.69.137.78]
^C
Re: waiting for....
08-09-2010 7:45 PM
0 geoffrey-PC [192.168.1.82]
1 home [192.168.1.254]
2 lo0-central2.pcl-ag03.plus.net [195
3 gi1-9-321.pcl-gw01.plus.net [84.92.
5 195.50.122.129
7 ae-42-42.ebr1.NewYork1.Level3.net [
15 lw-dc2-core4-ge2-15.rtr.liquidweb.c
16 lw-dc2-sec1-dist2-po2.rtr.liquidweb
4 te2-2.pte-gw1.plus.net [212.1
4 te2-2.pte-gw1.plus.net [212.159.0.1
Re: waiting for....
09-09-2010 10:24 AM
OK - I think I was off on a goose chase. The links I have in my bookmarks (firefox) are of course things like this http://www.machsupport.com/forum/index.php rather than just the domain name. So I was pathping'ing these and it didn't matter which of the sites I did, I allways ended up at the same place at the end of the traced route. I thought I had been spoofed but I (think) I now understand that I was just getting the "nxdomain" i.e. the destination of an unknown domain name. Probably makes more sense to you than me but I think I get it.
When I pathping just the domain names (like you did) - I get much the same sort of results. Perhaps a bit slower. FWIW here's the dump.
0 pc [192.168.xxx.xxx]
1 . [192.168.xxx.xxx]
2 lo0-central1.pcl-ag04.plus.net [195.166.128.241]
3 gi1-10-411.pcl-gw01.plus.net [84.92.6.224]
4 te2-2.pte-gw1.plus.net [212.159.0.186]
7 1-1.r1.ny.hwng.net [69.16.191.49]
11 ve1011.ar1.ph1.hwng.net [69.16.190.162]
12 network-69-16-135-202.phx1.puregig.net [69.16.135.202]
13 gi1-46.dr1.dg1.phoenix.codero.com [69.64.66.62]
14 machsupport.com [69.64.89.93]
1 0ms 0/ 100 = 0% 0/ 100 = 0% . [192.168.xxx.xxx]
2 37ms 0/ 100 = 0% 0/ 100 = 0% lo0-central1.pcl-ag04.plus.net [195.166.128.241]
3 48ms 0/ 100 = 0% 0/ 100 = 0% gi1-10-411.pcl-gw01.plus.net [84.92.6.224]
4 45ms 0/ 100 = 0% 0/ 100 = 0% te2-2.pte-gw1.plus.net [212.159.0.186]
5 47ms 0/ 100 = 0% 0/ 100 = 0% te2-4.pte-gw2.plus.net [212.159.1.102]
6 37ms 0/ 100 = 0% 0/ 100 = 0% 1-2.r1.lo.hwng.net [195.66.224.227]
7 106ms 0/ 100 = 0% 0/ 100 = 0% 1-1.r1.ny.hwng.net [69.16.191.49]
8 124ms 0/ 100 = 0% 0/ 100 = 0% 3-1.r1.ch.hwng.net [69.16.191.41]
9 173ms 0/ 100 = 0% 0/ 100 = 0% 1-1.r1.la.hwng.net [69.16.191.33]
10 181ms 0/ 100 = 0% 0/ 100 = 0% 2-1.r2.ph.hwng.net [69.16.191.38]
11 181ms 0/ 100 = 0% 0/ 100 = 0% ve1011.ar1.ph1.hwng.net [69.16.190.162]
12 178ms 0/ 100 = 0% 0/ 100 = 0% network-69-16-135-202.phx1.puregig.net [69.16.135.202]
13 172ms 0/ 100 = 0% 0/ 100 = 0% gi1-46.dr1.dg1.phoenix.codero.com[69.64.66.62]
14 170ms 0/ 100 = 0% 0/ 100 = 0% machsupport.com [69.64.89.93]
Trace complete.
Re: waiting for....
09-09-2010 10:26 AM
These are the sort of responses you should have got:
C:\Documents and Settings\John>pathping http://www.machsupport.com/forum/index.php
Unable to resolve target system name http://www.machsupport.com/forum/index.php.
C:\Documents and Settings\John>pathping www.machsupport.com/forum/index.php
Unable to resolve target system name www.machsupport.com/forum/index.php.
Unable to resolve target system name www.machsupport.com/forum.
0 elvin04 [192.168.0.104]
1 dg834 [192.168.0.1]
2 lo0-homesurf.pte-ag1.plus.net [195.166.128.65]
3 ge1-0-0-406.pte-gw2.plus.net [84.92.4.26]
4 1-2.r1.lo.hwng.net [195.66.224.227]
5 4-1.r1.ny.hwng.net [69.16.190.209]
6 3-1.r1.ch.hwng.net [69.16.191.41]
7 1-1.r1.la.hwng.net [69.16.191.33]
8 2-1.r2.ph.hwng.net [69.16.191.38]
9 ve1012.ar2.ph1.hwng.net [69.16.190.166]
10 network-69-16-135-206.phx1.puregig.net [69.16.135.206]
11 gi1-46.dr1.dg1.phoenix.codero.com [69.64.66.62]
12 mail.machsupport.com [69.64.89.93]
Computing statistics for 300 seconds...
^C
Re: waiting for....
09-09-2010 10:40 AM
OpenDNS is notorious for lying when you give it a duff name to look up, instead it will redirect you to sponsored sites.
I suggest you just use the Google DNS servers 8.8.8.8 and 8.8.4.4 (which don't tell lies) in addition to the Plusnet ones. Put the Plusnet ones first as they will normally be faster, the Google servers will then act as a backup of the PN ones are having an off-day.
Re: waiting for....
09-09-2010 2:01 PM
Where did you find that I was using openDNS though - just did a search on my own posts and I couldn't find anything (memory like sieve!)
Also - I changed my DNSs (in the router) as per post#1 of this thread at that date - but I guess something was cached locally, because it wasn't doing this on my laptop.
However - I did a DNS (and ARP) cache flush - but no change. Then I rebooted and I'm now where you are i.e. pathping'ing unknown domains returns "Unable to resolve target system name" instead of going to the "unknown name server".
Whether this will make a difference to my site/speed issue - who knows - but I'm glad this one was discovered and sorted thanks to you all.
Re: waiting for....
09-09-2010 2:25 PM
Quote from: purleigh Try changing your DNS settings to "8.8.4.4" and "208.67.222.222"
Quote from: whistler set dns as suggested and there appears to be some improvement. I'll watch it for a few days because as I said *sometimes* it's ok anyway.
Thanks all for your help. I'll get back after a few days with a morre meaningful update.
Cheers
Re: waiting for....
09-09-2010 3:19 PM
Quote You are using 208.67.222.222 which is OpenDNS.
However that was what I was advised in post #1 - ah well c'est la vie.
I took those two out this morning before I flushed the cash - also - as I said, my laptop didn't shown the "weird" - results for pathping - so I'm thinking this is all well and good I'll change my DNS to the google ones you suggest but I think this has all been a bit of a red herring as far as my actual OP is concerned.
- « Previous
- 1
- 2
- Next »
