thompson 585v8
- Feedback
- Plusnet Feedback
- thompson 585v8
thompson 585v8
01-06-2011 7:59 AM
so eventually i was swapped to 21CN then had my upload uncapped
but was still getting loads of errors on the thompson , was suggested the router was reporting incorrectly ?
so i managed to get a home hub2 which connected to PN with no problems brilliant connection ,no connect problems, lower pings,gaming was at last brilliant
which i have been using for the last few months.
now the other day just as a experiment i plugged in the thompson
so what i am getting at is , is it just my thompson ?, but i read here more people have trouble with the same router , are they realy up to the job they desiged for ? looks to me for general surfing they are fine but not for gaming
The HH2 is a lot better , would it be a idea for PN to look for a alternative for them to supply ,
Re: thompson 585v8
01-06-2011 9:46 AM
I don't game so can't comment on that subject - you've obviously found a solution and no doubt other gamers have their answer to the problem.
Supplying what is basically a free router has to be a compromise.
Re: thompson 585v8
01-06-2011 11:20 AM
Re: thompson 585v8
01-06-2011 1:04 PM
Re: thompson 585v8
01-06-2011 2:46 PM
I've been through plenty of ADSL modems since I had ADSL, from a Zoom modem, not router, through a Belkin ADSL modem, another Belkin, a Netgear, A Draytek etc etc. In other words, most routers that say they are ADSL compatible will work with this service. Sure there might be exceptions, but I've yet to come across one (and as above, have tried a fair few over the years).
Sorry, in short: If you don't like the free one, go buy a new one there are plenty out there at everything from budget basement price through to rolls royce prices.
Re: thompson 585v8
01-06-2011 9:06 PM
12 month contract Thomson v8 free
or
12 month contract, gaming type router at cost minus the cost of the freebie v8
if you get my drift
Re: thompson 585v8
02-06-2011 7:30 AM
as phil4 says there is plenty of choice but what one do you choose
so if i buy a N300 at £44 am i wasting my cash
Re: thompson 585v8
02-06-2011 9:55 AM
There must be gaming forums where one can get advice on routers that work well with a BT connection and I'd suggest looking there.
Re: thompson 585v8
02-06-2011 1:29 PM
Re: thompson 585v8
02-06-2011 8:27 PM
all i simply asked was that was, someone at PN must have knowledge to decide which alternative router would work better on their network than the thompson offerd free.
On my PC i know what upgrades will work and which wont as i built it to my spec,s for my use, so i woulnt ask PN for suggestions to upgrade , but as i am not to great on networking all i asked was some advice which router would be better , therefor would it be better to offer a better router at the onset of my connection going live as an alternative to the thompson.
not to hard to ask
Re: thompson 585v8
02-06-2011 8:48 PM
Even people on here suggest routers that perform better than others, Plusnets more techy staff will have an even better idea what is liable to perform.
The choice could easily be narrowed down, even Plusnet could afford 2 or 3 of the suggested routers for evaluation on the network, in fact I have no doubt if Plusnet talked to the manufacturers they would be given a couple to evaluate given the possible size of new business
Its in Plusnets interest to tie people into a contract, and some who would just go onto the no router, monthly option, no doubt would tie into a contract with the possibility of a upgraded router.
Although the Thompson serves my purpose I have a 15 y/o and a 12 y/o who are obviously into the gaming side of things so I for one may well have upgraded given the choice
Re: thompson 585v8
03-06-2011 8:01 PM
Re: thompson 585v8
07-06-2011 4:34 PM
Any ADSL2+ router should be compatible with PlusNet (the ones ofen markes as 'compatible with BT lines), there should be no need for testing. Some are bound to be better than others as prices range from not much over £10 to well over £100 but any device containing an ADSL modem should connect to a broadband enabled BT line unless it's broken. The lines and exchange are BT Wholesale and nothing is specific to PlusNet, the exchange equipment can be manufactured by any of several approved vendors and can contain different chipsets, different routers also contain different chipsets and some people believe that certain chipsets work better together than others, this just adds more uncertainty for most people - many router manufacturers do not say what chipset their products contain (some even change it while keeping the same model number - usually just a version change). If you can find a router known to have a Broadcom chipset the chances are that you will get decent stable performance but expect to pay a bit more.
Re: thompson 585v8
07-06-2011 8:24 PM
