still waiting
- Feedback
- Plusnet Feedback
- still waiting
Re: still waiting
02-06-2013 7:56 AM
thanks
Re: still waiting
02-06-2013 9:33 AM
Re: still waiting
04-06-2013 8:23 AM
Re: still waiting
06-06-2013 1:52 PM
Re: still waiting
07-06-2013 1:18 PM
Re: still waiting
10-06-2013 9:52 AM
FAQ
Results Image not loaded
1. Best Effort Test: -provides background information.
Download Speed
18.8 Mbps
0 Mbps 19.36 Mbps
Max Achievable Speed
Download speedachieved during the test was - 18.8 Mbps
For your connection, the acceptable range of speedsis 16 Mbps-19.36 Mbps .
Additional Information:
IP Profile for your line is - 19.36 Mbps
Upload Speed
8.94 Mbps
0 Mbps 20 Mbps
Upload speed achieved during the test was - 8.94Mbps
Re: still waiting
10-06-2013 1:09 PM
Re: still waiting
10-06-2013 2:35 PM
I've asked one of our faults team to pick this up for you, should be an update on there shortly - really sorry about this.
Re: still waiting
11-06-2013 9:56 AM
Re: still waiting
11-06-2013 10:17 AM
Re: still waiting
11-06-2013 10:40 AM
Re: still waiting
11-06-2013 10:53 AM
Log in to the Modem/Router, in the Internet box, click Disconnect to drop the PPP Internet session (this is not the sync), wait 30 seconds then click Connect. This should ensure the relevant servers are updated with the current sync speeds then run the BTw Performance test (ignore the red preamble except make sure no other programs are using the Internet) and at the end of the first run, click the Further Diagnostics button, enter just your Phone number and Run the Further Diagnostics Test.
That will give you the current BT IP Profile.
Re: still waiting
11-06-2013 11:31 AM
Re: still waiting
11-06-2013 12:05 PM
Download Speed
28.41 Mbps
0 Mbps 29.68 Mbps
Download speedachieved during the test was - 28.41 Mbps
For your connection, the acceptable range of speedsis 16 Mbps-29.68 Mbps .
IP Profile for your line is - 29.68 Mbps
Upload Speed
8.52 Mbps
0 Mbps 20 Mbps
Upload speed achieved during the test was - 8.52Mbps
This is less than it was before so what is my ip profile suppose to be as keep getting mixed messages from both sides. The engineer said this morning we should be getting close to what was quoted and the speed as more than likely been capped, this was after he re-set the dlm at the home not cabinet.
Re: still waiting
11-06-2013 12:11 PM
