slow speed,slow to none response.
Anotherone
Champion
Fixes: 21
Re: slow speed,slow to none response.
Well, first the good news, looking at those line stats unless you have a particularly noisy line, you may be able to get around 6M when your problems are sorted.
Now the not so good news, I hope you didn't buy that extension lead, or if you did, not paid much for it. Extension leads are often a serious problem for broadband. Were you using it, when you posted the results from the test socket?
The point of using the test socket is to eliminate anything between the exchange line and a direct connection to the filter and modem/router. Don't worry about rechecking yet if you weren't corrected direct, the information provided is useful.
The throughput speedcheck from the BT speedtester is consistent with the BT IP profile. The PN profile is a bit higher but will drop to match the BT one  Cry  This has happened because you've had a low sync speed event recently.
The better news is that the current sync speed (DSL connection rate) of 4832 would give a profile of 4M if held.
If you can give the following information it will help narrow down your problem.
Could you give an Outline description of your installation -
1) What Logo do you have on your NTE5 Master LineBox.?
2) Whether you have any fixed extension wiring and sockets & how many, and roughly how the cables go from one to another;
3) What filters do you have and where is the Modem/Router normally plugged in?
4) Do you have a corded phone, do you have a cordless phone - if so what type - DECT or Analogue?
5) Is any other POTS (plain old telephone service) equipment (Faxes, Answer phones, Sky boxes or Alarms systems etc) plugged in/connected.
One final tip: When you need to swap things around for testing, powerdown your modem/router and wait several minutes before unplugging anything that disconnects it from the line eg. it's cable, the filter, master faceplate etc. Don't do this more than 5 times in an hour, and then leave it alone for the rest of the day. This is to help prevent the exchange DLM (dynamic line management) from thinking you have a worse line problem than you may have.
Anotherone
Champion
Fixes: 21
Leaving your modem/router connected at the test socket is a sensible thing to do for the interim.
Can you post the current mode/router ADSL stats.
dabba
Hi Anotherone,
No problems regarding the extension lead I moved the computer to the same room as the master so no need for a lead I plugged in to the socket as shown by Jelv,
The socket has a BT logo and looks same as the picture by Jelv
I have several wired extension sockets but these have all been disabled by plugging in as instructed
the micro filter is a DSL-35MF which came with the router I did try an alternative but no improvement
normally I have Philips digital (CD 440) cordless phone plugged in but for the tests I removed it.
no other equipment is connected to this line.
I will power down  as directed when I disconnect anything, many thanks for your support. .
dabba
Mode :  G.DMT
Type: Interleave
Line Coding : Trellis On
Status : Link Up
  Downstream Upstream
Rate (Kbps) : 4832  448
SNR Margin (dB) : 13.1  22.0
Attenuation (dB) : 40.0  23.0
Output Power (dBm) : 19.8  12.1
K (number of bytes in DMT frame) : 152  15
R (number of check bytes in RS code word) : 16  16
S (RS code word size in DMT frame) : 1  8
D (interleaver depth) : 0  0
Delay (msec) : 0  0
Super Frames : 1587984  1587982
Super Frame Errors : 9  0
RS Words : 107982942  13497847
RS Correctable Errors : 7291  1894
RS Uncorrectable Errors : 120  N/A
HEC Errors : 8  0
OCD Errors : 0  0
LCD Errors : 0  0
Total Cells : 307649702  0
Data Cells : 528438  0
Bit Errors : 0  0
Total ES : 8  0
Total SES : 1  0
Total UAS : 26  0
latest stats as requested.
dabba
Anotherone
Champion
Fixes: 21
Thanks for those stats. It gives an idea how much noise your line picks up compared to this afternoon. Conditions are generally noisier an hour or so before sunset to an hour or so after sunrise. The stats still look good considering the Target SNRM.
Would you run the BT speedtest again, if you are lucky, you may find your IP profile has risen. If so, the PN one may rise within 12 hrs and then it will be worth running a throughput test. It is pointless before the profiles have recovered.
Try this one http://www.mybroadbandspeed.co.uk/ when both profiles are up.
I presume from what you've said, all the extension sockets are dead (which they should be) whilst you are plugged into the test socket. Could you look at the wires connected to the back of the faceplate you've unplugged at the master socket, hopefully there will be one cable with single wires connected to the terminals.
You should find a Blue+white trace on terminal 2 and a White+blue trace on terminal 5. You may also find an Orange-white and White-orange on terminals 3 & 4. If you unscrew your extension sockets from their boxes you should find identical colour wires connected to them. You should find two cables at the first extension socket, and so on until you get to the last one which should have one cable.
On the back of the extensions you hopefully will NOT find a yellow "sausage-shaped" capacitor on any of them. How many extensions have you got?
dabba
Plusnet support have advised they have asked the supplier to turn on interleaving which could take from 24hours to 5 days to have any effect I'm not sure what this is could anyone explain please, I'm leaving the computer plugged in on the test socket so any internal wiring has no effect I need to solve the line problem first!
when and if that gets sorted I'll look at the extensions if required or it would be no hardship to leave the computer where it is and have no need for any additional sockets,
dabba
speedtest 4pm today
128Kbps 325Kbps
Chris
Legend
Fixes: 169
Unfortunately something has caused the sync to drop down to 160 over the last couple of days, it's risen again back to 4064 so if you can stay stable at this speed hopefully your profile will increase with that.
You've been stably connected at that speed for near 20 hours now, so hopefully you've managed to eliminate as much of your internal wiring as possible now.
shutter
Fixes: 67
I am surprised at the above statement, as the router information you have already given, (reply 18) shows you have "interleaving)
check your router statistics page again...  Undecided
(@ Chris,  I think you will find he has not had any "internal wiring" to eliminate, as he is operating from his master socket.....and has been for some time...
Reply #5 on 07/12/2009, 14:25 »
Hi plugged in at the test socket speedtest
and also this posting......
« Reply #13 on 07/12/2009, 16:24 »
Quote from: Oldjim on 07/12/2009, 16:00
Are those results from the test socket.
If so can you post the router stats from your normal socket.
Do you have a Sky Box connected to the telephone and is it filtered
Yes these results are from the test socket
I do not have Sky TV
Reply no 20 today  also has this in it.....
dabba
Test1 comprises of Best Effort Test:  -provides background information.
Download  Speed
106 Kbps
0 Kbps 250 Kbps
Max Achievable Speed
Download speedachieved during the test was - 106 Kbps
For your connection, the acceptable range of speeds is 50-250 Kbps.
Additional Information:
Your DSL Connection Rate :4832 Kbps(DOWN-STREAM), 448 Kbps(UP-STREAM)
IP Profile for your line is - 135 Kbps
latest BT speedtest 15.30pm today
dabba
dabba
Hello just checked on my questions on the members centre, got the same reply today as yesterday
"we have asked our wholesale suppliers to turn on interleaving..............................could take up to 5 days "
dabba.
Mand
That's an automated reply 'cos the interleaving order failed, we've got a fix going through testing to sort that.
Your fault is with our faults team still, and they'll run some further tests, but I can see 3 disconnects today, which imply you've still got a problem there, hence the low profile.
dabba
latest BT speedtest  1.30 today.
Results Image not loaded
Download  Speed
215 Kbps
0 Kbps 7150 Kbps
Download speedachieved during the test was - 215 Kbps
IP Profile for your line is - 4000 Kbps
jelv
Fixes: 10
What's your current line speed on https://portal.plus.net/my.html?action=stable_rate ?
jelv (a.k.a Spoon Whittler)
Mobile: iD mobile (£4/month)
Anotherone
Champion
Fixes: 21
@Mand & @Chris
dabba's sync speed has been at 4832 since the 7th which is why his BT IP profile has now risen to 4000, if you can kick the PN profile to match, we ought to see and immediate improvement.
@dabba
I would advise you continue to keep your modem/router on 24/7 and not attempt to reboot it except mid-late morning at the moment and then only if absolutely necessary. A lengthy period of stability is desirable. Once your PN Line speed at the member centre matches BT's you should see a big improvement. If per chance you don't pick up the improvement after the figures match you may need to Gateway hop. To do so - use the Disconnect/Connect buttons in your modem/router's interface (192.168.1.1)
orbrey
Hi dabba (and thanks Anotherone)
I've upped the profile to 4000 to match BTs side, if you don't pick that up straight away just disconnect and reconnect and you should see the higher speeds.
