slightly concerned about peak times.
Kelly
Fixes: 9
Re: slightly concerned about peak times.
Hopefully BT can sort that link in your exchange soon!
Kelly Dorset
Ex-Plusnet Jobsbody
Blim
Lets hope they install more because FTTC is new in my area and if this is the beginning id hate to know how its going to end up. I live on the Isle of Wight and the chance of seeing new links are doutfull (under the sea).
Kelly
Fixes: 9
I mislead you with that post.  I'm sure the links are fine, it's actually exchange equipment that usually need upgrading.
Kelly Dorset
Ex-Plusnet Jobsbody
Blim
Ive had some really bad luck in the past, when I was in my prime playing ranked games at clanbase. Those days have gone and I'll never be that good again but I just feel as if things will always go wrong, I'm probably just being paranoid.
I can see you care thou, its out of hours and your trying to help still. I am very thankful of that man.
Blim
How long do you think it will take then to fix the overloaded equipment at my exchange because I forgot to take off the pro addon and I've been charged for it while you guys are unable to provide the server for that perk.
Chris
Legend
Fixes: 169
I'm happy to remove Pro for you and give you the discount for it on your next bill if you like?
Blim
Yes please.
Blim
Any news on my connection?
Things don't look good from this end. I'll keep a record of whats going on.
Right now it would seem using just 10% of my connection is a problem for latency. but 5am I can use the hole connection (download) without problems.
The password on the new router you guys sent me has changed twice now. Im having to reset the thing just so I can login.
Blim
Default Gateway: 195.166.128.186
Blim
orbrey
Morning,
Pro's now been removed and there's a £5.89 discount on there for next month for you. Hope the exchange is upgraded soon as well.
Blim
Afternoon,
thanks for sorting that out. Can you tell me who's responsible for my connection in regards to problems providing me with a internet service, Be it my exchange or a supplier at your end?
orbrey
By the sounds of it that would be us, whether the issue is across our network or needs escalating to our suppliers.
Blim
Am I not entitled to some sort of discount until this problem is fix?
Quote from: Blim
rongtw
Fixes: 12
Blim would be nice if PN give some discount to all customers until this is sorted  Angry
