shocked at the level of poor service i am receiving (phone and broadband)
RyanGould
Re: shocked at the level of poor service i am receiving (phone and broadband)
The virgin router we were supplied with was a d link 2640-R ADSL2 router
also, i know 15Mbs down and at least 0.66Mbs is possible because we got that with our previous provider. (see previous pages for speeds)
jim; where do i find that information?
tell me and i will post it
edit; also can you uncap my upload speed please?
pierre_pierre
instruction for getting router stats for most types of router are here http://www.kitz.co.uk/adsl/frogstats.php
RyanGould
Link Information
Uptime: 1 day, 0:32:29
DSL Type: G.992.3 annex A
Maximum Bandwidth (Up/Down) [kbps/kbps]: 888 / 5,184
Bandwidth (Up/Down) [kbps/kbps]: 440 / 4,760
Data Transferred (Sent/Received) [MB/GB]: 85.56 / 1.41
Output Power (Up/Down) [dBm]: 12.0 / 19.0
Line Attenuation (Up/Down) [dB]: 20.5 / 40.0
SN Margin (Up/Down) [dB]: 26.0 / 12.0
Loss of Link (Remote): 0
FEC Errors (Up/Down): 4 / 16,737
CRC Errors (Up/Down): 32 / 56
HEC Errors (Up/Down): 7 / 95
CX
Considering your 40dB DS attenuation, the estimated speed 9Mb (ADSL2+) or 7Mb (ADSL1).
Maybe there is some noise on your line which is preventing it from getting up to even those speeds, given this:
Even if the target noise margin was reduced to 3dB or 6dB, you're not going to get over about 5Mb.
Something physically must have changed with your line, because I don't see how you can possibly get 20Mb with those current stats. This is nothing at all to do with Plusnet - it's the physical line length between your home and the telephone exchange.
Force9Original
Quote from: RyanGould
Link Information
Needs a resync to go onto G992.5
What does it say on that BT wholesale line about the line speeds?
https://www.btwholesale.com/pages/static/Community/Broadband_Community/Coverage/ADSL_Availibility_Ch...
Also see what the line length is here on the Be* site line checker .
http://windows.mouselike.org/be/?DoAction=Checker
There is a chance BT have routed  the line differently during the repairs / switch over.
f9o Smiley
RyanGould
BT Recorded Line Length (m): 1567
and BT wont let me copy across the info but basically we are not supposed to get over 2 meg download down our line. (which is well off what speeds we have got before and what we are getting now)
Force9Original
Seems you''ve might of had a line had a re-route then.
The 1.6km would give you near full 20meg sync as you've said, but if the the new lenght is nearer 3.0km for  a 40db loop loss that would explain the issue.
The be* line length check would use a slightly older data point, while the BT wholesale is the most current. You can copy the bt wholesale page into notepad via ctrl -c or snap a sceen shot so we can see ,
Cheers f9o
Oldjim
Resting Legend
Fixes: 63
DSL Type:  G.992.3 Annex A is ADSL2 not ADSL2+
With ADSL2 the maximum frequency is limited to 1.1MHz and with ADSL2+ this increases to 2.2MHz
The probable reason you are seeing that is that the automatic systems have decided that your line won't stand the extra frequencies of ADSL2+ so you are seeing ADSL2 only
Have a read here if you some more information http://www.kitz.co.uk/adsl/adsl_technology.htm
Regarding noise margin I see that this has dropped from 15dB to 12dB and since you are in the training period I would assume that the automatic systems have decided that this is the lowest noise margin your line will support
RyanGould
so, will it get faster?
are we going to get changed over to anything else?
how lon do we have left on the training period?
Force9Original
If openreach have re-routed the line then your on the low speeds until fttc goes live no matter how much you or pn tweek the settings ;(
If anything that 40db will rise 1 or 2 db on adsl2+
Force9Original
The two red flags that say E-side switch,  a migration  and the serious line fault.
Its a difficult one as PN would be using the 1.6km figs for the 20meg speeds.
I'm not sure what can be done as openreach only have to provide a workable service.
RyanGould
in English?
im a pipe fitter welder so im not mega clued up on networking
pierre_pierre
ADSL1  DSL type is 992.1
ADSL2  is 992.3
ADSL2+ is 992.5
so it looks like you have gone up a bit to ADSL2, I have not seen that before, its normal to go from 992.1 straight to 992.5
I will leave that to the experts
RyanGould
alright, thanks for your help
Force9Original
Its just a guess, the line has been  re-routed.
It would  though, explain your high 14 meg on virgin & pn using that 1567m figure to  quote you the 20meg on sign up.
cheers f9o
