joint Plusnet - an incompetent service managed by nasty incompetent people
- Feedback
- Plusnet Feedback
- Re: joint Plusnet - an incompetent service managed...
Re: joint Plusnet - an incompetent service managed by nasty incompetent people
12-08-2011 2:24 PM
12-08-2011 2:34 PM
Quote from: timpurcell They started this battle not me and I've now had two apologies, a series of refunds and they are attempting to speed the process up. You may not like the method but it's working at least to some extent. Unfortunately it was entirely necessary to do what I did to get them to do this and I don't think anything I've said about the service on here is unfair because, up to the point where they started to budge, the company's behaviour had been outrageous. I'm afraid, however, that if I were an 80 year old pensioner without the confidence to fight my corner PlusNet would be cheerfully continuing to rip me off which, I'm afraid, is something I can't address. However this community might care to consider that going forward.
I hope that PN have not given you a series of refunds because I can't see from this thread any reason for it. Going back to the original failure of the install did you ask the owner or the caretaker of the block of flats you live in for advice or permission for the new line installation?
Why are PN a rip off?
There are a few 80 or approaching 80 year olds on these forums and they seem to be able to fight their own corner.
12-08-2011 2:39 PM
Quote from: itsme
12-08-2011 2:45 PM
Did you ask advice or permission of the owner or caretaker of the flats you live in to have a new line installation?
12-08-2011 2:52 PM
Quote I hope that PN have not given you a series of refunds because I can't see from this thread any reason for it
Indeed, i dont want my subscription paying for some idiot to have a hand out just to keep their custom.
Quote Did you ask advice or permission of the owner or caretaker of the flats you live in to have a new line installation?
Im guessing not, which is why BT failed to attend. In a block of flats you should always notify your Landlord, because afterall any alterations to the flat they could bill you for (e.g. BT put in a new master socket, and its in a diff location) -- Most people would do this out of curtosy and not to 'rock the boat' you seem to have no issue with trying to be as awkward, and abusive to whomever your speaking to
Wether they be fellow customers, moderators or staff.
Let him go
Regards
Quote its rather amusing to watch.
I concur (and no, im not 14, +7 actually.. ) arguign on the internet ftw !
12-08-2011 2:52 PM
Quote from: itsme Yes I have read the thread but I will ask the question again
12-08-2011 2:54 PM
Quote from: Matt_2k34
12-08-2011 2:58 PM
Quote How else would you like me to explain it.
(to go back to the first page)
How about raise a complaint via the procedure as outlined *on the first page*
Your clearly getting no-where and alienating people. Why is it such a burden for you to do what your supposed to be doing, rather than just coming on a forum to vent and try and be a PITA about it?
Quote He was very nearly not able to do the work required because he required access to parts of the building I didn't even know existed. This wasn't explained to me beforehand.
Clearly attended, clearly couldnt do the work (as indicated even by yourself) - so the access to parts of the building im assuming is a locked maintenance area, which is used by the landlord / building operator to have the tenants "by the balls" so they can cut services for failed payment, without involving BT/SKY etc.
Regards
12-08-2011 3:00 PM
12-08-2011 3:04 PM
Quote from: timpurcell You're asking a question about a minuscule element of the whole matter and I can't be bothered to answer it. I shan't be responding to your posts going forward as I don't want to engage with you. However I would like to point out that the refunds I have received from PlusNet so far relate to charges for services that they haven't actually delivered yet and for the delivery of substandard equipment.
A simple yes or no answer would be okay. I'm not sure why you have singled me out not to engage with as my postings have been brief with simple questions.
12-08-2011 3:23 PM
Not trying to moderate here (it's not our job) but please calm down. There's genuine reasons for complaint and anger here I'm sad to say, and these service issues do need dealing with.
@timpurcell - we've had the expedite accepted and confirmed, the broadband should be active on Monday 15th. I'll check and confirm first thing on Monday morning and make sure the account is active on the same day rather than waiting until the Tuesday.
12-08-2011 3:32 PM
12-08-2011 3:33 PM
Quote from: Matt Hi all,
12-08-2011 3:44 PM
12-08-2011 3:49 PM
You cannot expect PlusNet / BT to guess the internal cabling structure of the refurbished warehouse where you live. In purpose built or refurbished multi tenant/leaseholder premises the usual configuration is that BT Openreach deliver the service to the basement of the building. Generally delivery of the telecom service to the apartment is over copper pairs installed by the owner for that purpose. This helps to avoid extra wiring being dragged though the service ducts in the building during the life of the building. During the building/refurbishment the owner will arrange for master sockets to be wired within the apartment using the building cabling system. Given the shared occupancy of the building the owner's representative (caretaker) will need to control access to the MDF board in the basement where the external cabling meets the internal cabling.
In some less well organised buildings there will be no such provision for internal telecom wiring and the usual mayhem will preside.
The BT Openreach service provision does not allow funding for a pre-installation inspection visit in every case. They will normally attempt the install in a single visit, having pre-scheduled connection at the exchange end of things. Sometimes this does not happen smoothly and an extra visit would need to be scheduled. PlusNet have little control over this process other than raising the order against OpenReach in the first place and then raising reported faults via the OpenReach Help desk.
Is my understanding correct that you didn't use the standard equipment provided by PlusNet for the service? If so that will likely add to any installation issues.
You certainly have an aggressive manner in your postings and that is unlikely to help the resolution of problems if you use the same approach with the PN Customer support staff. Consider your ultimate objective. Do you want to get the service working or do you just want to throw your toys out of the pram?
My personal experience of PlusNet is that on the whole their staff are professional and helpful. If any member of their team is not helpful I know that they address the matter.
- Feedback
- Plusnet Feedback
