home phone-order cancelled
cbf150s
I bought a broadband contract online yesterday. Today, I received an email that says, 'your order for Home Phone has now been cancelled.' However, there's no reason / explanation given.
Does this mean that Plusnet won't take over the existing phone line or has the contract been cancelled?
18 REPLIES 18
MatthewWheeler
Fixes: 501
Re: home phone-order cancelled
It looks like the order was cancelled by your existing provider saying your not moving?
Can you PM me your address?
After the 3rd of November I will have a limited presence here as I have moved to a new role
 Matthew Wheeler
cbf150s
PM
cbf150s
If you have any information about what happened, please give me an update.
MatthewWheeler
Fixes: 501
I've replaced the orders and I'm just monitoring them.
 Matthew Wheeler
cbf150s
Just received another similar email saying the order for home phone is cancelled. Why is this happening again and again?
newagetraveller
Quote from: Matthew
you're not your. Not very professional Matthew. Smiley
cbf150s
Would appreciate if someone from the company could confirm I'll still get the broadband.
cbf150s
The 14 day period to cancel the contract ends tomorrow and I have no idea if I'll get broadband or not.
Someone help! Should I cancel?
Fixes: 195
Quote from: cbf150s
There are a multitude of reasons why an order gets cancelled by BTw / BTOR.
As a first step, I'd look at double checking your order details - phone number, address, post code.  Sometimes the reason an order get repeatedly cancelled is that the wrong circuit has been identified and the cancellation is the other subscriber (correctly) rejecting the transfer request.
This needs CRT to investigate and report back.
What is somewhat unfortunate is that once an order has gone pear shaped, fixing the detritus in the ordering system can be challenging.
cbf150s
Thanks for the heads up. Yes, the details are correct. Smiley
During the order, I did confirm that I want Plusnet to take over the existing phone line.
MatthewWheeler
Fixes: 501
Can you plug a handset into the phone socket and dial 17070.
That should read the number back to you. Once you've got that if you can PM me it we can try and find out why the orders are cancelling.
 Matthew Wheeler
Fixes: 195
Please double check the phone number you write down from the above and that on the order.
I have screwed up a BB order in the past by transposing two digits in the number I ordered the line for - it is too easy to do!  Grin
HarryB
Fixes: 256
Nice suggestion, however there's no number on the order as it will be going through as a working line takeover from what I can see.
I have a feeling this might have something to do with where the lines are registered, it's possible that the line showing at the address is actually not actually at the address and belongs to a neighbour. If there is a line at the address (Physically) it may be registered to a different address Roll_eyes
We won't actually be able to confirm this until we have the number and we've sent an ALID request off. Even then it might not give us a definitive answer.
 Harry Beesley
cbf150s
The handset didnt work when I plugged it in the phone socket. (for some reason there are two, tried both). Maybe there isnt a working line afterall or the handset could be broken, found it in a random drawer in the flat.
