diabolical upload speed
- Feedback
- Plusnet Feedback
- diabolical upload speed
- « Previous
- 1
- 2
- Next »
Re: diabolical upload speed
26-03-2014 10:26 PM
http://www.speedtest.net/results.php?sh=f67df3e98a20adf1056b02d465de1c1a&ria=0
26-03-2014 11:51 PM
Quote from: phawley Taken from Think Broadband website re factors affecting BB speed.
Where you live—The distance from your home to the local telephone exchange is the most common factor which affects DSL broadband services as the signal degrades the longer it needs to travel. If you have a fibre-optic broadband connection, you're less affected as the distances are shorter (from your home to the street cabinet instead of the exchange; see the fibre broadband guide for more details)
How near you live to your local exchange will affect the speed of your broadband. If you have fibre broadband, your speed shouldn't be as affected by line length.
Try reading what you've quoted properly.
Quote from your home to the street cabinet instead of the exchange
The distance from the cabinet to your home will affect speed. In fact VDSL drops off more quickly with distance than ADSL.
27-03-2014 9:12 AM
Unfortunately, in some circumstances, some customers do live a fair distance away from it which is the cause for low speeds. If you're unhappy with the speeds you're receiving, my advice would be to raise a fault with us at http://faults.plus.net and our Faults Team will take a look and will determine, in greater detail what can be done, if anything to improve things.
27-03-2014 12:26 PM
Quote from: jelv
I can read it perfectly and it says that if I have fibre then my speed should not be affected by line length.
Another point is that the length of copper from my home to the cabinet has not changed, obviously the only change is the fibre from the exchange to the cabinet and if you are saying that the fibre is slower then everyone using that cabinet will be affected,
jim:green quote fixed mod:end
27-03-2014 12:54 PM
The bottom line here is, regardless of what any website says, speeds are always going to be dictated by distance with this technology. ADSL/VDSL use different frequencies which is why you see such a dip in speeds over slightly longer distances.
27-03-2014 1:00 PM
As I have just explained to Chris Pettit in a PM, the length of copper from my home to the cabinet has not changed and yet I have had better speeds the only thing that has changed is the fibre from the exchange to the cabinet and if that is as you say then A What is the point of installing it and B everyone using the cabinet would be affected.
27-03-2014 1:04 PM
Quote from: Chris With VDSL/FTTC distance is an absolutely important factor. FTTC is great if you live within a close vicinity of the cabinet, but if you have a fair bit of a distance between your property and the cabinet, the speeds start to dip quite considerably, as I've mentioned before and linked you to http://www.increasebroadbandspeed.co.uk/2013/chart-bt-fttc-vdsl2-speed-against-distance
But you are saying that the speed drop is in the fibre, then what is the point in installing it?
27-03-2014 1:37 PM
See the graph that I've linked you to, it shows just how drastically the speeds drop at a certain distance.
27-03-2014 2:37 PM
Quote from: phawley I can read perfectly thank you
Hmmm... I think not!
Quote from: phawley and what I read is " If you have fibre broadband, your speed shouldn't be as affected by line length"
A tiny but important little word. It is not saying you won't be affected at all. The affects of distance from the cabinet are different because as Chris has pointed out VDSL uses higher frequencies that drop off much faster over the longer distances.
27-03-2014 3:43 PM
27-03-2014 3:57 PM
I'm saying that FTTC uses a higher frequency which would cause a much more noticeable speed loss (as you can see) whereas on ADSL the frequency is lower and thus doesn't lose as much speed over extended distances.
Most of your D-side cabling is underground, and although road distance to your cabinet is relatively, it's actually quite long looking at Openreach's documentation for your line (around 2.5km).
27-03-2014 3:58 PM
27-03-2014 4:25 PM
80Mb is sent from the cabinet and depending on the distance the signal has to travel will depend on what speeds you get. As above, the longer it has to travel and the higher the frequency will depend on what sort of range the speeds will start to dive.
The upstream is quite relative to the downstream. A full 80/20 line will probably see through speeds of around 17Mb on the upstream, and the same rule applies, the longer the distance, the lower the speeds are going to be. The downstream is going to be a little more forgiving as it uses more of the frequency than the upstream does which is why you see higher speeds always given on the downstream than the upstream.
Back in the day, some business needed high upstream and downstream which is why SDSL was introduced.
- « Previous
- 1
- 2
- Next »
