are you stupid?
- Feedback
- Plusnet Feedback
- are you stupid?
Re: are you stupid?
23-12-2009 6:17 PM
Re: are you stupid?
23-12-2009 8:22 PM
local DNS cache?
Re: are you stupid?
23-12-2009 8:36 PM
Others will treat it as low priority traffic that can be thrown away if necessary.
A few sites will treat multiple pings from the same address in a similar way as a denial of service.
If you want to measure latency you need to use TCP packets - not ICMP ones.
Ping is just a tool to get a rough idea of connectivity.
Re: are you stupid?
24-12-2009 6:28 PM
Your original Question 1:56pm, Thursday 24th December 2009
Dear Mr Lewis Williams-ward,
We have asked our wholesale broadband suppliers to turn interleaving on on your phone line to try and fix your current broadband problem.
Interleaving is a form of error correction that helps to improve the stability of high-speed broadband. One drawback of interleaving is that it can increase ping times, which may cause problems for online gamers.
We think that turning on interleaving may help with your connection problems. Interleaving usually takes 24 hours to turn on, but can take up to 5 days to take effect.
If interleaving solves your problem, please close this Question. If you are still seeing problems with interleaving switched on, please return this Question to us with as much detail about your problem as possible. Thank you for your time and patience.
Kind regards,
PlusNet Customer Support
yet again im being sent this [Censored]
jim:quote
Re: are you stupid?
24-12-2009 6:49 PM
Re: are you stupid?
26-12-2009 7:28 PM
dick:quote
Re: are you stupid?
26-12-2009 10:47 PM
Which is how to wireshark a PS3 connection.
Re: are you stupid?
26-12-2009 11:51 PM
monkey001: Have you tried a different wireless channel yet? What problems do you see when using a wired connection?
Re: are you stupid?
27-12-2009 12:32 PM
Re: are you stupid?
27-12-2009 6:17 PM
Quote from: jelv I don't think Wireshark is needed yet - it looks like the problem may not with the Plusnet connection but internal.
yeah i just changed it from 11 to 10 and it went crazy couldnt load my router page back up for about 30mins took some ping times on it .
found the same problems with it wired on ping times
Re: are you stupid?
27-12-2009 6:18 PM
Re: are you stupid?
28-12-2009 12:44 AM
Re: are you stupid?
28-12-2009 2:01 PM
If you choose one of 1, 6 or 11 then you won't overlap with anybody else on the "standard" channels.
Re: are you stupid?
01-01-2010 1:43 PM
been waiting since the 15th for interleaving to be turned back off but everytime im just fed bullshit next week is the last chance
Re: are you stupid?
01-01-2010 2:01 PM
