Would I recommend Plusnet? , Possibly, but Openreach are a joke
leadhead
Re: Would I recommend Plusnet? , Possibly, but Openreach are a joke
Unfortunately I also had a similar experience to the OP, 3 no-shows by BT, and an engineer showed up on the 4th appointment, but only because he had finished his scheduled morning work, and rang in for another job. Had I not been relatively close to his last job, I could still be waiting.
Re speed, Ive only been connected for 20 hours, but after only reaching speeds of around 5mb using wireless, I wired it and now have speeds of around 32mb.
I'll look into the wireless problem, but apart from a billing issue, and a compensation query, I'm quite happy at the moment.....(hope thats not "famous last words"..) Embarrassed
orbrey
Hi leadhead,
Looks like that's all been sorted for you, I'll pop an update on the ticket you've raised.
leadhead
Thanks Matt,
Speedy and very satisfactory outcome.....
Lets hope I'm as happy with my new fast BB.....
dick:quote
leadhead
Quote from: leadhead
[Moderator's note by Dick (Strat):  Full quote of preceding post removed, as per Forum Rules ]
Apologies, I will study the rules
