Wireless Connection
Frustration
Wireless Connection
Have just moved to Plusnet. Received the router and set it up as directed, could not establish a wireless connection. Was supplied with another router - same problem. Have now spent two days on trying to set this up, can anyone help? My inclinantion having entered this forum and read some of the posts is to cancel order and revert back to Orange, although more expensive, they do have an efficient support call center
3 REPLIES 3
pierre_pierre
Re: Wireless Connection
as per the other post today, have you entered the WPA code into you PC, the PN Thompson router has WPA security enabled when delivered, the code is printed on the bottom of the router, and IAEFRTBM,  which came as a printed sheet with the router
ReedRichards
Seasoned Pro
Fixes: 25
It should not be any harder than setting up an Orange Livebox.  Did you have one of those or is this your first time trying to use wireless?
Andrew_B
Hello.
I've had a quick look at your account, and I can see that you've managed to get connected since posting here.
Are you still having trouble or are things sorted out now?
