WiFi Access
itsme
Re: WiFi Access
I also use a business hub so I know it's BT Openzone on that but will be interested to know that it's the homehubs that have it as BTFON.
Wheel_nut
Re: WiFi Access
I have a couple of Home Hubs that I bought off eBay but I don't want to take the 2700HGV off the line because I am trying to get my SNR Matgin back down to 6db
I seem to remember that it doesn't configure the second SSID unless you configure it as a"BT Total Broadband" Customer so I don't know how I cold find out. I am in a very low housing density area so can't pick up any neighbouring signals.
orbrey
Re: WiFi Access
Hi all,
It's something that we've done in the past, though there was very little takeup so we dropped it - it's certainly been talked about recently but there's nothing imminent in the pipeline. Rest assured we'll let you know as soon as something is decided though.
pierre_pierre
Re: WiFi Access
I have a BTHomehub 49E6 on the scanner that is WEP  and a belkin open but very low signal strength
