Why no answer after 4 days?!
pfwcooper
Please reply to my question posted in the 'member centre'! I posted it 4 days ago and tumbleweed...
i'm asking why i only recieve 36Mb when i'm paying for 76Mb. not even half the promised speed...
2 REPLIES 2
Oldjim
Fixes: 63
Re: Why no answer after 4 days?!
If you can post the results of the BT speedtest Further Diagnostics we will have a good idea http://speedtest.btwholesale.com/
orbrey
I've tweaked the profile on your account, you're showing as having a profile of 77400 on BTs side of things so that's now matched - should improve things for you. Please bear in mind though that you're paying for up to 76Mb, not 76Mb - therefore the speed may be lower (you can get a line estimate at http://dslchecker.bt.com/) but as we charge for usage and not speed we wouldn't be able to reduce your subscription fee.
Hope that helps.
