Why can't Plusnet provide what BT can ? No broadband since joining
- Feedback
- Plusnet Feedback
- Why can't Plusnet provide what BT can ? No broadba...
08-09-2015 5:43 PM
I moved to plusnet and apparently they are not capable of providing the same, blaming the length of my line - of course my house and the exchange are in the same place as they were when BT provided me service with no problems.
Today they offered to cancel my contract so they did not have to fix my issue - this is a joke.
Anyone from plusnet care to comment ?
Re: Why can't Plusnet provide what BT can ? No broadband since joining
08-09-2015 5:45 PM
08-09-2015 6:11 PM
To say they can't provide a service because of where I live is a joke when I have had adsl for years !!!!!! Plusnet broke it they should fix it not try to wash their hands.
08-09-2015 6:30 PM
08-09-2015 8:09 PM
Quote from: amgas Plusnet broke it they should fix it not try to wash their hands.
A warm welcome to the forums.
I know that this is not want you want to hear, but (setting aside the possibility that you have been 'provided' on a up to 1Mbps BTw product) PlusNet did not break this - BTOR did.
The speed at which your link synchs is governed solely by the BTOR owned, managed and maintained equipment between your home and the exchange. PlusNet does not have any control or "touch" on that equipment.
If you are being advised that you are "too far from the exchange" then that will be a decision made by BTOR, not PlusNet. The truth might be something more like "your line has deteriorated and there are no serviceable spare pairs between your home and the exchange over which a decent service can be provided".
Clearly the actual reasons need CRT comment.
08-09-2015 8:29 PM
At a guess, you will have a new router, and this may be the problem.
A few years ago I had a project supplying broadband services around the country many in rural locations. I found the old BT Business 2 wire router could supply higher speeds and more reliable service than many other routers.
Even though I can throw stones at my local exchange, I don't by the way, the 2 Wire router would give me full adsl speeds, whereas a BT Homehub would not. Due to cost constraints, the ISP supplied routers are not always the best quality, or give the best line speeds. It sounds like you are a long way from your exchange, whilst I can't see PlusNet supplying a better router, you could do worse than having a look on eBay, and getting a 2 Wire router and trying that, or something similar.
08-09-2015 8:44 PM
Quote from: Mustrum What apart from changing suppliers has changed?
That's just the point - we do not know. Remote rural areas ofthen have aluminium wires which do deteriorate. BTOR might have been messing with the circuits and there might be no decent ones left. Rather than repair them, BTOR will simply say service cannot be provided.
09-09-2015 9:47 AM
Quote from: Townman Hi,
I can also confirm it isn't provided on an 'up to 1Mbps' product.
We've been investigating this as a fault for the past month, the engineer notes from last week state the following:
Quote from: Engineer CIs test and demonstrated to EU. eclipse and PQT ok from nte unable to do. A5 min sync test as tester would not sync. enduser in sync at 244k this is a 8000k circuit and the line length in 8126m unable to speed up as long line issue.
09-09-2015 10:19 AM
Is there room for a push back here - request boost engineer? If previously this line did better than it does at present, then it suggests something in BTOR's realm has deteriorated and needs to be rectified. Leaving PlusNET with egg on its face is just not acceptable.
BTOR need to test the line from the cabinet back to the NTE as well. It's not unheard of for PQT to pass OK from NTE but fail from the cabinet. I'm guessing there are no spare pairs? In which case BTOR need to get into every cable joint and renew the crimps. Is there aluminium involved here?
Is PlusNET still progressing this problem with BTOR?
@Amgas,
You really need to work with PlusNET on this one. This is a BTOR issue; no matter which ISP you might consider using, your BTOR circuit is not going to change. Stupid as it sounds, no ISP has much clout with BTOR and the esclation channels are limited.
One way of addressing situations such as yours is to write direct to the CEO of BTOR - ask why their equipment which used to do X can now only do Y and no effort us being made to fix things? Also ask why are BTOR's technical issues are being made a commercial issue for PlusNET? You might not get a reply (I have not had one to 3 such emails) however it will open doors for PlusNET within BTOR's esclation processes much sooner than the months BTOR's standard esclation processes take.
Also bringing BTOR's failure to adequately repair their equipment to the attention of Ofcom might not result in a quicker fix, but it will raise another black mark against BTOR's failure to deliver.
Kevin
09-09-2015 10:31 AM
09-09-2015 10:53 AM
That is a sound question which calls into doubt the OP's recollection of synch speed or BTOR's 'measurement' of the line length. As you imply, it is not likely that both are true.
BTw's historic stats for the line should indicate previous synch speed attainment and loop loss metrics.
@amgas,
Can you please post your full router stats.
Whilst I'm thinking modems (routers) what were you using when you were with BT? Do you still have it? If yes have you tried using it with the PlusNET service? You will need to change the user details.
Some modems are better with poor lines than others. I'm guessing you are using a 2704n from PlusNET at present? That said, the test equipment would not synch at all, yet your modem does synch. One starts to question the quality of the test equipment used by BTOR.
09-09-2015 11:02 AM
Quote from: AndyH Is the OP's line is 8126m, how could he possibly have been getting 1.5Mb with BT on a stable connection?
His line has been swapped at some time to a different pair which follows a more circuitous route? (Of course an OR engineer would never do such a thing to fix someone else's issues - would they?)
09-09-2015 11:08 AM
I doubt the line length has suddenly increased by 3-4km though.
09-09-2015 11:30 AM
Are you saying the OP is being economical with the truth?
Quote from: amgas I had stable 1.5 mbit connection with BT for 2 years.
09-09-2015 11:35 AM
Something clearly isn't right here though.
- Feedback
- Plusnet Feedback
