When a PN employee calls
w23
Fixes: 4
Re: When a PN employee calls
One of my credit card issuers uses a personalised picture and text combination on their website when I log in to help ensure I'm not caught out by a phishing link or similar taking me to a false site, it wouldn't be difficult to set up a 'reverse password' to achieve the same on telephone calls as suggested by Mayfly (simple idea but really good thinking).
Call me 'w23'
JohnJ-B
One of the Banks, that I used to be with, agreed to a reverse-password system. However, when they phoned up, refused to provide it until AFTER I had cleared THEIR Security!!
Duh!!  Sad
plusnettony
Fixes: 46
I am sure it would be quite easy to actually provide a generic support number. What I meant by my comment was that it has more to do with operation reasons than technical.
 Tony T
Fixes: 235
...that is choice and not impossible.  Wink Roll_eyes
HPsauce
Seasoned Pro
Fixes: 5
Quote from: plusnettony
Easy but useless and inapproprioate.
It needs to be a number which is answered (not multiple-choice press this for that nonsense) when you call back, by someone who can deal PROMPTLY AND EFFECTIVELY with a customer who says simply and honestly - "You called me".
HairyMcbiker
All Star
Fixes: 21
Nope if it was from one of the PN recognised numbers then it would give MORE precedence than a withheld number, not that it would/should be takes as actually them.
