What a damn shambles PlusNet is in.
- Feedback
- Plusnet Feedback
- What a damn shambles PlusNet is in.
- « Previous
- Next »
Re: What a damn shambles PlusNet is in.
15-01-2014 12:17 PM
15-01-2014 3:44 PM
The creaking back-office system is a potential Achilles heel in the plans to expand the business? Are there any plans to review / replace.
M
15-01-2014 4:10 PM
You would think logically before your embarked on a massive marketing drive , you would first have the correct amount of staff ( in relation to projected increase in users ) , make sure your back end systems are up to the task ( billing, ticketing system, regarding updates and back of the que, has been like this for years, but nothing has been proactively done, from the customers point of view ) , then do your marketing drive.
I think PN has done it back to front , and in this instance does not deserve to use "well'll do you proud" because you have not.
Having said that hopefully things will be back to normal soon.
Regards
Mike
15-01-2014 4:13 PM
Quote from: I I was told last week they are going to be building a new billing system from the ground up this year.
As I understand it the rebuild is under way but being a massive project it won't be finished any time soon.
15-01-2014 4:18 PM
Quote from: MauriceC The creaking back-office system is a potential Achilles heel in the plans to expand the business? Are there any plans to review / replace.
As a member of PUG I'd have expected you to be aware of the system rewrite in progress. I'm not sure what that says about the relevance of PUG these days!
16-01-2014 6:12 AM
Quote from: I I was told last week they are going to be building a new billing system from the ground up this year. ...
Why build a new subscription system when you can buy one off the shelf such as Zuora?
16-01-2014 8:01 AM
16-01-2014 11:40 AM
Quote from: Scott need to integrate with other existing systems such as our CRM which isn't a small amount of work.
Yes I'm aware of the complications and likely time scales, I've managed similar projects starting back in 1980 for both bespoke and package software solutions. It depends really if Plusnet is in the business of writing software or whether the primary business is providing telecoms for consumers/businesses. Whichever solution is provided it is needed quickly.
16-01-2014 11:59 AM
- « Previous
- Next »
