Webmail - time for a facelift?
worcsdave
I'm getting fed up with Webmail, and especially the need to type in an authentication code before I can send each email.  I know it's only a small point, but it's so easy to make a mistake here, and it just slows the whole process down.
Are there any plans afoot to make Webmail a sleeker, smoother experience?
6 REPLIES 6
bobpullen
Fixes: 330
Re: Webmail - time for a facelift?
Quote from: worcs
This only happens when your using Webmail from a non-UK IP address.
Yes, but the plans have been on hold for a considerable amount of time. I'm about to drop you a PM so keep an eye out for it...
csogilvie
Quote from: Bob
It used to be any non-Plusnet IP address... has this changed?
bobpullen
Fixes: 330
I might be wrong in which case Colin, it's definitely one of the two though! Tongue
Lurker
I thought it was the latter initially, then this was gradually relaxed to be the former.
Not too certain though.
Oldjim
Resting Legend
Fixes: 63
about 3 weeks ago it was fom any non Plusnet IP - such as Sky
rookey
Nice to see someone mention about a facelift for the webmail... As I have just started using it after 4 years due to being away from home quite a bit and need to read my mails...  I too think it sooo  boring and need spicing up a bit
