Volume of complaints re: slow speed
- Feedback
- Plusnet Feedback
- Re: Volume of complaints re: slow speed
30-07-2009 3:49 PM
http://img.villagephotos.com/p/2006-10/1221023/capture15.jpg
30-07-2009 3:55 PM
What results do you get from a 'normal' speedtest?
30-07-2009 5:02 PM
Quote from: Jameseh The media rumours that are being referred to are a demonstration of shocking journalism based on technical untruths from the BBC.
I personally don't believe that we're seeing more genuine speed complaints (barring recent Usenet issues) and I deal with them on a daily basis.
I think (this time) it's unfair to blame "shocking" journalism.
The story reads at http://news.bbc.co.uk/1/hi/technology/8172065.stm
Quote Nearly one fifth of UK broadband customers on an eight Megabit per second (Mbps) connection actually receive less than 2Mbps, it found.
The research showed that less than 9% of users received more than 6Mbps.
However, the report shows that average connection speed across the UK is 4.1Mbps, up from 3.6Mbps in January.
A test like the one below can give you an indication of your current connection speed.....
Actually carrying out the suggested test gave a speed of 5.1Mbps - the PN speedtester gave a result of 5.3Mbps.
These results were obtained around teatime.
30-07-2009 5:26 PM
Quote Print Thread
Standard User JonathanDabbs
(newbie) Thu 08-Jan-09 20:59:03
Print Post
TBB Speed Test Slow Namesco Fast?
[link to this post]
I have noticed that over the past couple of months some of my results from the Think Broadband speed test have been exceptionally slow way less than 100kb/s.Normally they vary between 2-5 Mb/s depending on contention.
Immediately using the Namesco speed test at http://www.speedtest.bbmax.co.uk/ always shows the speed to be in the normal 2-5Mb/s range.
I have also confirmed these speeds by the speed of downloads and on demand video which always works fine even when the TBB speed tester is really slow.
My conclusion is that there is an intermittent bottleneck between TBB and Demon. What seems strange is that it's either ok i.e. speeds fom other sites agree with TBB or TBB is way way below the rest.
Has any one else noticed a similar effect from Demon or any other providers.
Speed Test Results
Date 30/07/09 17:22:06
Speed Down 5828.87 Kbps ( 5.7 Mbps )
Speed Up 376.18 Kbps ( 0.4 Mbps )
Port 8095
Server speedtest1.thinkbroadband
30-07-2009 5:28 PM
Quote from: Jameseh Surprisingly not! The BT Speedtester is notoriously inaccurate.
If that's the case then why am I wasting my time providing three BT tests for CS?
30-07-2009 5:31 PM
The Synch speed is OK, the Profile is OK, but the throughput is all over the place
30-07-2009 5:32 PM
The Indian call centre didn't have any connection with BT outreach, so
it was impossible to progress a fault.
This is why foreign call centres are a bad thing.
30-07-2009 6:23 PM
14-08-2009 5:21 PM
Download Speed: 921 kbps (115.1 KB/sec ) Upload Speed: 356 kbps (44.5 KB/sec )
My Broadband Speed 917 upload 356
14-08-2009 6:27 PM
it depends on what package you are on and what you are trying to do as some things are capped, see below for Value and Unlimited (as to how much not speed)
see http://www.kitz.co.uk/isp/plusnet_shaping2.htm for more
24-08-2009 10:11 AM
url=http://www.mybroadbandspeed.co.uk]
[/url]
24-08-2009 7:14 PM
25-08-2009 2:22 PM
25-08-2009 2:40 PM
25-08-2009 2:55 PM
