Volume of complaints re: slow speed
- Feedback
- Plusnet Feedback
- Re: Volume of complaints re: slow speed
29-07-2009 9:03 PM
29-07-2009 9:21 PM
AHHHHHHHHHHHHHHHHHHHHHHHHHH!
29-07-2009 9:32 PM
Get with it lads
29-07-2009 10:06 PM
what router stats do you get, and router if you like.
PN's standard router - as Pierre alludes to is the Thomson TG585v7 - and I too have been using one for 7 months with same stats as Pierre.
29-07-2009 10:24 PM
We carefully monitor our customer growth coupled with usage patterns and ensure we're ahead of the curve when it comes to capacity requirements. The number of centrals and segments we've lit in the recent past will bear that out and indeed we're not far off lighting more.
As other's in this thread have said, if you have a specific problem post up the details and we'll have a better understanding of the nature of the problem. There are a wealth of factors which can and will influence the speed customers receive and our capacity is not going to be one of them.
29-07-2009 11:09 PM
Quote from: Mark and I'm not aware of any increase in speed issues
So what's your explanation of the dire Usenet speeds being reported in these forums?
29-07-2009 11:54 PM
I was with Entanet before and getting on average 6.4Mbps
Plusnet average 5.4Mbps [insert emoticon to express extreme fury]
30-07-2009 6:58 AM
30-07-2009 9:29 AM
Quote from: drewid I was with Entanet before and getting on average 6.4Mbps
Can I ask what affect only having an average of 5.4Mbps instead of 6.4Mbps have on your enjoyment of using the internet?
30-07-2009 10:26 AM
Quote from: Mark To be clear, we're not oversubscribed and I'm not aware of any increase in speed issues, short of the issues raised by some rather uneducated reporting in the media recently, but thats another story.
To be frank though you're not going to come on here and publicly state that you are aware of speed issues or being over subscribed are you?!
Lets also face it the media only get wind of a story through things that have happened - Rumours. Rumours only come around when stuff causes them. What could of caused these rumours then?
Yes we're all aware that you measure your customer growth and usage patterns - thats what causes you to start tinkering with the prioritisation AGAIN and upset customers even more.
You guys can not understand upset customers full stop. Thats bad.
30-07-2009 10:31 AM
I personally don't believe that we're seeing more genuine speed complaints (barring recent Usenet issues) and I deal with them on a daily basis.
30-07-2009 2:52 PM
These constant attempts to pretend that there are no problems when anyone watching the forums with two brain cells to rub together can see there are is getting me pretty pissed off!
30-07-2009 3:11 PM
Quote from: pierre_pierre yes it does say it all you are using an unreliable speed tester try http://www.mybroadbandspeed.co.uk/ instead
Oh! you mean the one OWNED by Plusnet, Yeah right.
And how do you know if the speed tester I'm using is unreliable or not?
30-07-2009 3:18 PM
Quote from: drewid This says it all. http://img.villagephotos.com/p/2006-10/1221023/capture14.jpg
Pierre: I would rate the TBB speedtester as being reliable - it is not unknown for Plusnet to ask users what speeds it reports so I'm pretty sure they are happy with the results it produces.
30-07-2009 3:24 PM
jim:quote
