Very dissatisfied
chrispurvey
Re: Very dissatisfied
Hello,
Hope everything went OK with your install. From everything I can see it has gone through fine. Your speed profile has updated, hopefully you will have seen the positive change but if you haven't I would suggest doing a soft disconnect/reconnect. This would require logging into your router's interface, then disconnecting and then reconnecting. The reason I say this is your speed profile has been updated after your last connection was established.
Let me know how it's going.
jelv
Fixes: 10
Quote from: Arno
I have a router so no problem at all.
I hope that's not a standard ADSL router!
jelv (a.k.a Spoon Whittler)
Mobile: iD mobile (£4/month)
