Using dial up to report a fault
quantium
Last night we were struck by lightening and the modem was destroyed. I have got some spares so replaced it, but got connection to the exchange only. I was unable to connect to
username: [email protected]
password: test
without success.
I asked neighbours (on BT) to see if their broadband worked, and it did, so assumed that I was unable to connect because of some setup error with my replacement modem. I then tried to connect to Plus Net by dial up and spent fruitless hours trying to find the page that would say whether there was any known fault. Once I had found it, it reported none. I then wanted to raise a ticket, but couldn't find the link. We then bought a 3G USB HSPA "dongle" to try and get connection, but by the time we got back with it, service had been resumed.
Clearly the strike had affected the local PN network, but this was not reported on the Plus Net web site. Obviously the information was available somewhere, but I spent most of the morning looking for a non existent fault in my own network.
I would like to recommend that there is a quick link so that customers can get a support ticket open on dial up with the minimum amount of connection time. A simple link, say "http://ticket.plus.com" that brings up a form right away.
As a side issue, fibre to the premises would make lightening strikes a thing of the past. Lightening cannot pass down optic fibres! Ducting has been laid down out road now, but I am told that we can only have fibre to the cabinet.
A more immediate solution may be to have optical links coupling the copper to the home to the customer's modem. This would obviously be possible to implement. Get the Chinese turning them out! Optical AV is already here, so this would use similar technology.
5 REPLIES 5
adamwalker
Fixes: 223
Re: Using dial up to report a fault
Thanks a lot for the suggestions, glad to see you're back online too.
I sincerely doubt we would have been aware at such short notice, if our suppliers report any such localised issues we'd report them on our service status page http://status.plus.net if they affect a large proportion of our customer base, otherwise we should be checking for them as part of the process of investigating faults for customers.
 Adam Walker
jelv
Fixes: 10
Quote from: quantium
I'm not sure about this. Very few users will have a dial up modem or even if they had an old one laying around have any idea on how to set it up manually (also old dial up modems will need a serial port and how many PCs made in the last few years have those!).
A far more radical solution would be for Plusnet to give a telephone number which would be answered within minutes by an agent who could check the BT notifications.
If you look up your exchange at http://usertools.plus.net/exchanges/ and then use the link in
You can view recent Service Outages for this exchange here
you will see if BT published information about the outage.
It might also be listed on http://usertools.plus.net/exchanges/mso.php
jelv (a.k.a Spoon Whittler)
Mobile: iD mobile (£4/month)
MauriceC
Resting Legend
Fixes: 17
I have to agree with Jelv.
I am fortunate to have a couple of old Dial-up modems  but finding a working one would be a challenge likely to take longer than BT Openreach would take to fix the fault Grin
billnotben
Quote from: jelv
I don't think that statement is quite true.
Every laptop I've had, including the one I'm using now, had/has a software dial up modem built in.
w23
Fixes: 4
Yes, this laptop has a 56k modem too (though I've never actually used it).
I imagine many websites would be terribly slow to load at modem speed.  I have a 'text only' browser in Linux (Lynx) but not sure if the modem works with Linux.
Call me 'w23'
