Upgrading to hub 3
Fronk99
Re: Upgrading to hub 3
its here
Fixes: 382
It isn't.
Fronk99
sorry it doesnt accept docx so I sent pdf
Fixes: 579
WiFi 5 will max out around the 400Mb. I believe the contracted speed applies to wired connections. Certainly my FF900 connection will give around 910 on a wired. speed test but only around 370Mb wireless when sat around 10ft from the router
Fixes: 382
@MisterW Thanks for that - I know you have posted those stats previously, but couldn't remember them. However, the OP has a WiFi6  card. 😔
Fronk99
i wonder how many people have seen 900 even on a cable.
Fixes: 382
See post #19 - at least one. 😀
Fronk99
Thanks very much all, we`ll see how it goes. have to take the furry one for a walk now, have a good evening.
Fixes: 579
Makes no difference , the Hub 2 is only WiFi 5!
Fixes: 382
I forgot. 😁
bobpullen
Fixes: 330
The maximum wireless PHY rate that can be achieved with a Plusnet Hub Two is 867mbps. You can roughly half that to give you an approximation of what the maximum wireless throughput is.
RealAleMadrid
Fixes: 68
@Fronk99  There are no guaranteed or minimum contracted speeds for a wi-fi connection, if you think that you will be able to break your contract for poor wi-fi speeds you are mistaken. As for the 14 days you mention, I assume you are referring to the order cooling off period which is 14 days from the day after you ordered the Broadband service to comply with distance selling regulations. It is not a testing facility.
Fronk99
With respect I was with Sky Broadband for 76 days and they do have a refund guarantee if your speed is below the contracted minimum, in my case that was 100 mb/s, after talking to 20+ customer service reps and 4 tech guys they could not fix the issue. I was refunded each months payment as their criteria was 4 consecutive days below contracted. In the whole 76 days I only saw 100 + a handful of times so I dumped them. To give them credit they didnt argue and sorted the refunds very quickly.
I`m sure Plusnet would have something similar as I have not yet seen anything over 500 mb/s but I`m prepared to wait and see if the connection settles.
Fixes: 382
You won't see the top figures with the Hub2 on wireless. As has been said, you either need a wired connection, or a more powerful router.
Fixes: 476
@Fronk99
Extracted from the T’s and Cs.
4. Quality of service
4.1. We aim to provide a continuous, high-quality service, but we can't be responsible for:
4.1.3. ensuring equipment we provide allows you to get a wireless signal everywhere within your home or delivers the speeds possible over a wired connection wirelessly.
